jani12
What are software and hardware requirements for a embedded system mounted on a rifle scope?
I need to specify detailed image processing and graphics overlay requirements for state of the art rifle scope? I'm looking to specify the entire pipeline starting from image sensor to display. The specification needs to be comprehensive. It'll be used to select resources such as Integrated circuits, knobs, buttons, memory, etc.. The specification will also drive detailed design document and will be used to validate the final product.
Image sensor needs to be monochrome, with sufficient resolution, high dynamic range. I also need to specify image sensor calibration but what is the need to calibrate image sensor? How calibration works in a typical image sensor from BAE Systems?
The specification should include Reset Initialization specification, Normal Operation Specification, and Fault Operation specification.
