Results 1 to 5 of 5
    Newbie level 3
    Points: 24, Level: 1
    Feb 2019
    24
    [Moved] How to read TTL Signal from sensor with Microcontroller ?
    Can any one help me to read TTL signal(5V TTL-Compatible) to read with Microcontroller ?I am having Pressure sensor with output TTL. Sensor having 3 pins One is Vcc ,GND and Signal(5v -TTL Compatible ).
    I am using stm32 Nucleo board . Please suggest me how to read it .
    Thanks,
    •   AltAdvertisment
    Points: 70,762, Level: 64
    Apr 2014
    14,471
    70,762
    64
    [Moved] Re: How to read TTL Signal from sensor with Microcontroller ?
    To get a good and reliable answer you should:
    * give us the exact type and vendor of the sensor, or (a link to) the datasheet
    * give us the exact type and vendor of the microcontroller, or (a link to) the datasheet
    * the schematic, with addition information like: voltages, part values...
    In detail:
    V_OH of the sensor needs to be compatible with V_IH and V_Imax of the microcontroller.
    (V_low usally is not problematic, but it's a good idea to check it, too)
    Often the voltage levels depend on circuitry and power supply voltage.
    You say "5V TTL compatible"...
    But is it a true push pull TTL output, or just "TTL compatible"?
    A true TTL output drives a HIGH signal higher than 2.0V, whereas a "compatible" output can be a "open collector" whuch needs an external pullup resistor to get valid HIGH levels.
    •   AltAdvertisment
    Newbie level 3
    Feb 2019
    24
    Re: [Moved] Re: How to read TTL Signal from sensor with Microcontroller ?
    Thanks for your reply,
    Micro controller link -- https://www.st.com/en/evaluation-too...eo-l073rz.html
    Sensor vendor link -- https://www.digisens.ch/images/S018E_12_KL66.pdf
    Please let me know the inputs to read the data with MCU.
    •   AltAdvertisment
    Newbie level 3
    Feb 2019
    24
    Re: [Moved] How to read TTL Signal from sensor with Microcontroller ?
    The sensor datasheet just says "5V TTL (compatible)" ouput.
    Thus it should be
    LOW: <0.4V
    HIGH: >2.4V
    according TTL standard.
    (You could easily find the values on your own: Just do an internet search for "TTL voltage levels")
    This is not what I was asking for.
    Please show a little effort on your own: Read the microcontroller (not the evaluation board) datasheet and find out V_IH and V_Imax. (as already meantioned in post#2)
    Mind: The signal is no "digtal data" signal. Itīs just a frequeny. --> you need to do a frequency measurement.
    Thanks for your reply ,
    I have tried it on my own only ,but everywhere i am seeing what is a TTL signal couldn't find how to interface read them with any MCU .
    If you could explain me that would be really appreciated .
    Can i able to read this signal using ADC of micro controller before that many docs i found that TTL is nothing but a native serial .I don't have clarification on it .
    Kindly help to solve this .
    Thanks,
    Apr 2014
    14,471
    70,762
    64
    [Sorry for the confused order of posts]
    Thus it should be
    LOW: <0.4V
    HIGH: >2.4V
    I wonīt look for the datasheet, download it and search the document for "V_IH"...
    It is your job, and if you want others do your job you should consider to pay for this.
    But even for this you need to give the requested information: exact type of microcontroller.
    It is a simple task you need to be able to do this on your own.
    With almost every datasheet there is a section "electrical characteristics" ... there it should be easy to find "V_IH".
