[AVR] Eclipse Compiling error with AVR
6TheNightWhisper9
Newbie level 6
Dear All
I'v used Eclipse to create a simple AVr application for ATMEGA8A, but after compiling the code i got an errors which is generated with any avr application coded by the Eclipse,so pls help to solve these errors
my code is
Code C - [expand]
8
9
#include <avr/io.h>
int main()
   DDRC |= 1<<PC0;
   while(1)
     PORTC0 ^= 1<<PC0;
and the errors are
make: *** [LedOnOff.o] Error 1
recipe for target 'LedOnOff.o' failed
and the details for the auto generated make file ,which contain the errors belong to subdir.mk file
# Automatically-generated file. Do not edit!
# Add inputs and outputs from these tool invocations to the build variables
C_SRCS += \
../LedOnOff.c
OBJS += \
./LedOnOff.o
C_DEPS += \
./LedOnOff.d
# Each subdirectory must supply rules for building sources it contributes
%.o: ../%.c
@echo 'Building file: $<' "the error is here"
@echo 'Invoking: AVR Compiler'
avr-gcc -Wall -Os -fpack-struct -fshort-enums -ffunction-sections -fdata-sections -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega8a -DF_CPU=16000000UL -MMD -MP -MF"$(@:%.o=%.d)" -MT"$(@)" -c -o "$@" "$<"
@echo 'Finished building: $<'
@echo ' '
and the toolchain configuration as below
AVR-GCC C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin
GNU Make C:\Program Files (x86)\Atmel\Studio\7.0\shellutils
AVR Header Files C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include
AVRDude C:\Program Files (x86)\Arduino\hardware\tools\avr\bin
many thanks
Are you compiling only, or are you also trying to download/run/debug this program ? I would bet there are more than one programs attempting to make access to this file at same time, e.g compiler and debugger; just guessing.
The "make" utility can't find the source file LedOnOff.c
As the compile rule is written, that file must be located in the directory above the one where LedOnOff.o will be generated.
Hi my friend
I put LedOnoff.c in all the folders belong to the project, but i've got the same error
Hi My friend
I compiling only a release version without debug ,also enabled avrdude to burn the generated hex file
The output from compilation seems too short.
Try invoking make in verbose mode, it should be something like that:
make V=1
The purpose of this statement is not to elliminate the error itself, but rather to change compilation output to verbose mode, which at first sight could give more details on the error reason.
