Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
  1. #21
    Points: 70,746, Level: 64
    Apr 2014
    14,465
    70,746
    64
    Re: Interfacing interlocks with pic controller
    the circuit is correct now.
    Hint: instead of 2 x BAT54 you may use one BAT54S
    The circuit will protect the input.
    But it will not suppress contact bouncing.
    Both informations are already given in this thread:
    * contact bouncing time
    * how to calculate tau
    •   AltAdvertisment
  2. #22
    Points: 77,353, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,659
    77,353
    67
    That is correct.
    •   AltAdvertisment
  3. #23
    Full Member level 5
    Points: 1,666, Level: 9
    Sep 2016
    261
    1,666
    9
    For Tau,
    10K X 100nF,then it have to divide by 1000 for milliseconds..?
    Pull up resistor is placed in right position..?
    If we using an interlock signal as +5VDC instead of GND means also shall we use this same circuit expect pullup resistor..?
    •   AltAdvertisment
  4. #24
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,659
    77,353
    67
    Yes, all correct. The protection is against voltages outside of VSS and VDD so it will work when the interlock is active low or active high, just swap the pull-up resistor for a pull-down instead.
  5. #25
    Apr 2014
    14,465
    70,746
    64
    No, I don't think this is correct.
    There are two series resistors, one for overvoltage protection, the other as filter.
    Both corrupt V_IL to the microcontroller input, as they act as resistor divider in combination with the pullup resistor.
    Use the pullup resistor at the most left side, then you are safe.
    Btw: I'd go more low ohmic with the pullup. I'd say 10mA as switch current is not too much.
    •   AltAdvertisment
  6. #26
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,659
    77,353
    67
    22K pull up/down with 2K total series resistance to the switch should give a low of 0.4V or a high of 4.4V. Most 5V PICs have a low guaranteed at 0.8V and a high at 2V so technically it should be OK.
    As this is an interlock and therefore not driven, I think I would drop the 1K series resistors to say 470 Ohms if there were worries about logic levels not being reached. If in doubt, move the pull up/down resistor to the interlock input instead of the PIC input. The circuit should function exactly the same.
