Results 1 to 16 of 16
    Full Member level 4
    Points: 2,883, Level: 12
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    how to match calculated and measured current of a brush DC motor ?
    hello dear forum,
    I have a full bridge driving a 24 V DC brush motor
    I have measured the max current of H bridge with ACS sensor with STM32 uC
    and wrote down for four different duty of PWM
    I also measured the Vsource
    I measured the L and R of the motor with LCR meter
    I locked the rotor of the motor
    however the calculated I max and measured I max are very different from each other
    I have attached an excel file for calculating the I max of RL circuit from power electronics book of Muhammad Rashid
    I tried with diferent R and L however still not a match
    what am I doing wrong ?
    please advise
    thank you
    Points: 77,053, Level: 67
    Apr 2014
    15,611
    77,053
    67
    Re: how to match calculated and measured current of a brush DC motor ?
    I assume you just donīt take waveform into account.
    Donīt use "RMS" measurement here, neither for voltage nor for current
    Donīt use "max" measurement method.
    --> use "average" measurement method.
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    hello ,
    Where can I find the formulas for calculating the average current ?
    my final goal is to find the speed of the motor from current measurement
    thank you
    Points: 259,231, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,259
    259,231
    100
    Difference between peak and average current isn't very large in this circuit, the observed differences between calculation and measured currents can't be explained this way.
    There are however unclear points:
    - what's the H-bridge switching pattern?
    - is it correct to neglect switch voltage drops?
    - does the H-bridge driver involve dead time respectively asymmetrical delay?
    Without an actual motor voltage waveform, it's mostly guessing.
    Speed is primarily set by applied voltage. Current measurement may be used to correct for the torque related speed reduction.
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    hello ,
    gate signals of one leg ( the other leg Low MOS always ON )
    IR2183 driver has 500 ns deadtime
    motor voltage and current waveforms (ACS sensor output)
    MOSFET data
    STP100NF04
    N-channel 40V - 0.0043Ω - 120A - TO-220 - D2PAK
    STripFET™ II Power MOSFET
    how to calculate the current and speed of motor correctly ?
    which formulas are valid ?
    thank you for your help
    this is the current signal when motor locked - other waveforms same
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,259
    259,231
    100
    You are apparently showing the D=0.35 case, calculated and measured peak current is only 5% apart here. If you are asking why the difference is so big for D=0.14, you should show the respective measurements.
    As for your general questions, it's useful to determine the average current over a PWM period, average current is proportional to motor torque. Speed is in a first order proportional to motor voltage, or more exactly motor emf, terminal voltage - voltage drop at winding resistance.
  7. #7
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    I locked the rotor and give different duty and measured average , max and min motor current
    I have 750 W transformer 220 / 24 V which I rectify and apply to circuit
    I took 30 measurements in 100 uSec ( PWM frequency is 10 Khz )
    I quicksort algorithm the measured data
    I took average of 30 measuremets for average
    took average of 3 most high measurements for I max
    took average of 3 most low measurements for I min
    as mentioned above I calculated R of motor from average measurements
    the R is not constant ( I need constant R value for calculating speed when motor is running - isnt?)
    I dont understand - I am stuck
    neither average calculated R is constant
    nor I max calculation from formulas of Muhammad Rashid power electronics book
    gives same values as measured data
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,259
    259,231
    100
    D=0.141 waveforms?
  9. #9
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    0.141 duty
    gates
Name:	gate 014 duty.JPG
    motor Voltage and current
Name:	current 014 duty.JPG
    I have one question ; should not the current waveform be like this ?
Name:	freewheel diode.JPG
    thank you
  10. #10
    Apr 2014
    15,611
    77,053
    67
    are you sure you gave the system enough time - before each measurement - for the values to stabilize.
    Mind:
    the first PWM periodīs average current will be low.. then it will increase...after a certain time it will not increase (noticably) anymore. Then itīs time to start the measurement.
    Mind:
    that the coil (copper) will become warm... the warmer the higher the copper resistance.
    coil waveform is different form driver waveform
    * coil: triangle shape
    * driver: like your hand drawn picture.
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,259
    259,231
    100
    No. The motor current should be triangular (integral of the rectangular motor voltage). The current through an inductor can only change continuously. The shown waveform clarifies that the motor doesn't behave purely inductive.
    My first question is if there are additional components between H bridge and motor, e.g. filters, clamping diodes, saturated inductors. What's the exact motor type, does it involve eddy currents?
  12. #12
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    @Klaus: I wait 3 seconds until circuit stabilize
    the ACS circuit is at the input to the H bridge
    @FvM:
    there is an electrolytic capacitor parallel to H bridge C18 1000uF
    U10 is ACS current sensor
    D37 D38 are not present
    component values are not real
    other than that it is a standart H bridge
    the motor label
    the motor is standart DC brush motor with 24 V brake
    Its current can be 50 Amperes when the wheelchair is against an obstacle
    thank you
  13. #13
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,259
    259,231
    100
    O.K. that's unexpected. You are measuring H-bridge DC link current rather than motor current. The deviations from expected waveform in post #9 can be mainly explained by capacitor C18.
    If you are interested in motor current, I would measure it directly. Peak currents will be always different, motor average current can be probably calculated by putting in bridge duty cycle.
    Imot,avg = IDC,avg/D
  14. #14
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    @FvM
    thank you for your answer
    //// Imot,avg = IDC,avg/D \\\\\
    is there a webpage or book, where I can find this equation and theoretical explanation of this ?
  15. #15
    Apr 2014
    15,611
    77,053
    67
    a paper, a pencil, drawing both current waveforms, estimating the average of both currents, estimating the relationship of both average currents....
    --> maybe you can safe the cost for the book.
  16. #16
    Full Member level 4
    Jan 2009
    Istanbul , Turkey
    196
    2,883
    12
    @Klaus @FvM
    hello thank you for your advise
    however I didnot take pencil and paper but I opened MS Excel
    and calculated R_motor with FvM's formula
    and it worked really
    now I have another question
    The IR2183 gate driver has 500 ns dead time
    the motor current can reach 50 Amperes max at 24 V
    my question ; is this deadtime enough ?
    or what value does it have to have ?
