gmin conductance problem in tspice
rimi17
Newbie level 1
Warning : "common_source.sp" line 38 Power supply node V2 is singularly attached to V2, and will be terminated with a Gmin conductance
Conventional DC operating point computation failed.
The above warning is obtained from the circuit shown below.
Can you please suggest me how to solve this problem.
... clearly refers to a file.
I recommend to upload this file (or at least a useful part of the file)...
Otherwise nobody knows what's the content of line 38.
No, it isn't. Cocktail napkins don't give error messages.
Malformed netlists do. There isn't a "V2" on the napkin.
Some simulators don't like nodes and elements having
the same name, but that's not the emitted complaint.
It is a thing to beware, however. I prefer to call a
source driving node V2, "VV2" just for portability.
I suspect V2 is the 10V supply that's indicated by
a "tie" on your napkin sketch, and somehow not
connected to anything.
However it's also possible that the PMOSFETs are
subcircuits operating in "empty husk mode" because
you forgot to include the .model statements (there
would be other errors about that, and you should
not be asking about an excerpted error without being
sure there are none preceding it. Responding to the
tail of an error log is often futile for this reason.
