Results 1 to 4 of 4
    Junior Member level 1
    Points: 913, Level: 6
    Apr 2015
    19
    913
    2D Music + Spatial smoothing [FMCW MIMO radar processing]
    Hi everyone,
    I'm using a 2D Music algorithm for the estimation of Range-Azimuth info in a ULA FMCW MIMO radar.
    The algorithm procedure is pretty simple (see "Belfiori F., Application of 2D MUSIC Algorithm to Range-Azimuth FMCW Radar data" or " Manokhin G., MUSIC-based algorithm for range-azimuth FMCW radar data processing without estimating number of targets"). I have some doubt with regard the application of the 2D FB spatial smoothing in order to decorrelate the covariance matrix of the data; I'm wondering if I do some error in the following code section (in the way I order the x_win_new vector):
    x= DataV'; %Data collected by the ULA (31 Spatial samples-31Antennas), 501 time samples
    N = size(x,1); % Number of antennas
    M = size(x,2); % Number of samples in fast-time dimension
    % window dimension for the smoothing dim[m1xm2]
    m1 = 25;
    m2 = 300;
    p1 = N-m1+1; %positions in the spatial dimension
    p2 = M-m2+1; %positions in the time dimension
    N_submat = p1*p2; %number of all the possible scan
    M_tot = m1*m2;
    ind_tot=1;
    for p1_ind = 1:p1
        for p2_ind = 1:p2
            x_win_new(:,ind_tot) = reshape (x(p1_ind:m1+(p1_ind-1),p2_ind:m2+(p2_ind-1)),[1,M_tot])';
            ind_tot=ind_tot+1;
        end
    end
    X_win_cor = x_win_new*x_win_new';
    X_win_cor_conj = conj(X_win_cor);
    J= fliplr(eye(M_tot)); 	%transition matrix
    C=(1/2*N_submat)*(X_win_cor + J*X_win_cor_conj*J);  %data smoothed covariance matrix (forward+backward)
    so in my case I'm scanning the full 2D [NxM] matrix in this way:
    x x x .      . x x x      . . . .      . . . .
    x x x .      . x x x      x x x .      . x x x
    . . . .      . . . .      x x x .      . x x x
    If I select m1=M and m2=N (so no spatial smoothing, only forward/backward averaging) I get good results as shown in the attached image.
    Thanks a lot in advance,
    Best regards,
    Apr 2015
    19
    913
    Re: 2D Music + Spatial smoothing [FMCW MIMO radar processing]
    A few more lines to make this more clear:
    My main questions are:
    1) Is it appropriate the use of 2D spatial smoothing to the data collected by an ULA?
    2) If yes, which is the right way to organise the subarray? Which directions the subarray has to scan the full data matrix?
    In the attached image[the music plot are theta/range type; θ from -20° to 20°; the FFT plot are in cartesian coordinates].
    As you can see in the second music plot (where I used m1=25; m2=300) something went wrong; it seems that the data smoothed covariance matrix has been not build correctly.
    Any suggestions?
    Thanks,
    Full Member level 3
    Points: 1,113, Level: 7
    Oct 2017
    151
    1,113
    7
    Although I have already talked about this topic with Luca privately, I leave a message here in case someone experience similar problems with radar data processing.
    To obtain better radar image quality:
    1) I have added padding with zeroes of windowed signal:
    wnd=hann(ptsNum);
    data=data.*wnd;
    pad=floor((2048-ptsNum)/2);
    data=[zeros(pad,1);data;zeros(pad,1)];
    2) Used simplest possible 1D FFT signal processing
    3) Added peak finding and thresholding
    4) Scaled data (20 points per meter)
    5) I build radar image using 2D histogram style approach. For each reflector accumulates in 2D map using pretty big 15x15 Gaussian kernel (R=7) point. If more points per meter is used, Gaussian kernel radius must be increased.
     if  ((xx>0) && (yy>0) && (dist>1*distScale))
      for dx=-kernelR:+kernelR
       for dy=-kernelR:+kernelR
        radarImage(yy+dy,xx+dx+xAdd)=radarImage(yy+dy,xx+dx+xAdd)+kernel(dy+kernelR+1,dx+kernelR+1)*amp1(lc1(k));
       end;
      end;
    To be honest I do not have experience with "MUSIC" algorithm. But as you may see on image below, even simple FFT with image processing approach gives pretty good result. I think this result may be improved further with Luca's knowledge and experience with "MUSIC" algorithm. I think that better resolution may be achieved , and sharper image of strong reflectors in the soil. Current result of simple monopulse-style processing:
    Newbie level 1
    Points: 37, Level: 1
    Aug 2019
    37
    Hi there, I am also working on the 2D MUSIC algorithm and based on the same paper but got the image wrong. Can you share your code? Much appreciated!
