Alan8947
Full Member level 4
I am looking for small signal BJT that has very low leakage current when the base is biased at about 0.2V. I have issue of transistors drawing collector current when the base is at about 0.25V that is way less than the normal turn on of 0.6V to 0.7V. I am currently using BC546 or 556, and KSA992 or KSC1831 transistors, they leak too much. I need transistor with as low collect capacitance as possible ( low Ccb and Cce).
BTW, how do I look for this on the data sheet? Looking at leakage at Vceo?
