Results 1 to 6 of 6
    Points: 856, Level: 6
    Jan 2016
    48
    856
    Generate random sequence of 1's and -1's in matlab
    How do i generate a random sequence of 1's and minus -1's in matlab with mean 0?
    Points: 15,719, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,396
    15,719
    30
    Re: Generate random sequence of 1's and -1's in matlab
    x0 = 1:40;
    y0 = 2*int32( randn( size(x0) ) >= 0.0 ) - 1;
    Also see https://www.edaboard.com/showthread.php?373245#6
    Jan 2016
    48
    856
    This doesnt always give a mean of zero
    Full Member level 5
    Points: 1,257, Level: 8
    Jan 2019
    254
    1,257
    8
    Re: generate random 1's and -1's in matlab
    the rand function generates uniformly distributed random numbers
    if you tell it to generate random numbers between 0 and 1,
    you can convert those less than 0.5 to -1 and those greater than 0.5 to 1
    Points: 256,485, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,740
    256,485
    100
    By nature of random distribution, an arbitrary selected sample can't have exactly zero mean otherwise it's not random.
    You may want to specify additional properties of the random distribution, e.g. maximal imbalance for a given sample length.
    Oct 2006
    Real Homeless
    2,396
    15,719
    30
    Quote Originally Posted by Chinmaye View Post
    If length of random sequence is enough large, average is zero.
