Results 1 to 10 of 10
    Points: 31, Level: 1
    Feb 2019
    31
    nRF24L01 and ESP8266 in Arduino UNO
    I have been trying to push data into my API from Arduino UNO with ESP8266. The device connects to WiFi but fails in performing the data push after acquiring from sensor node via the nRF24L01 module attached to the arduino. Any idea?
    •   AltAdvertisment
    Points: 28,981, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,630
    28,981
    41
    Blog Entries
    8
    Re: nRF24L01 and ESP8266 in Arduino UNO
    Are you sure that nRF24L01 is compliant with 802.11 such as ESP8266 is ? It seems like you are trying to connect modules having different wireless communication standards.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    Feb 2019
    31
    Since Arduino is working as a medium between both can't I send the acquired data using the esp module
    Nov 2006
    Brazil
    8,630
    28,981
    41
    Blog Entries
    8
    Initially I assumed a scenario with only one module of each of the above mentioned. Anyway, what do you think of, instead of giving short details, how about showing a description of the overall architecture in a slightly more elaborate way, such as a sketch, scribble or something like that?
    •   AltAdvertisment
    Feb 2019
    31
    i am sending here the receiver node code that gets the sent data from a remote node via nRF24L01 module and updates the thingspeak API with the esp8266 module. Arduino Uno is the interface
    #include <SPI.h>
    #include <nRF24L01.h>
    #include <RF24.h>
    #include <Wire.h>
    #include <printf.h>
    #include <SoftwareSerial.h>
    #define RX 10
    #define TX 11 //for SoftwareSerial to communicate with the Tx and Rx of the WiFi module
    RF24 radio(8,9); //CE,CSN
    const byte address[6] = "00001";
    String AP = "*******";
    String PASS = "******";
    String API = "9O1EQOC9QR5LMSS9";
    String HOST = "api.thingspeak.com";
    String PORT = "80";
    String field1 = "field1";
    int countTrueCommand;
    int countTimeCommand;
    boolean found = false;
    int data;
    SoftwareSerial esp8266(RX, TX);
    void setup() {
      Serial.begin(9600);
      Serial.println(F("This is the central receiving node"));
      esp8266.begin(115200);
      sendCommand("AT",5,"OK");
      sendCommand("AT+CWMODE=1",5,"OK");
      sendCommand("AT+CWJAP=""+AP+"",""+PASS+""",20,"OK");
      countTrueCommand = 0;
      radio.begin();
      radio.openReadingPipe(0, address);  //setting the address at which we will receive the data
      radio.setPALevel(RF24_PA_MIN);  //can set this as minimum or maximum depending on the distance between the transmitter and the receiver
      radio.startListening(); //it sets the module to receiver mode
      Serial.print("Radio set for communication");
      radio.printDetails();
    void loop() {
      if (radio.available())  //looking for the data
        radio.read(&data, sizeof(data));  //reading the data
        sendCommand("AT+CWJAP?=0",5,"OK");
        String getData1 = "GET /update?api_key="+ API +"&"+ field1 +"="+String(data);
        Serial.print("data received: ");
        Serial.println(getData1);
        sendCommand("AT+CIPMUX=1",5,"OK");
        sendCommand("AT+CIPSTART=0,"TCP",""+ HOST +"","+ PORT,15,"OK");
        sendCommand("AT+CIPSEND=0," +String(getData1.length()+4),4,">");
      delay(5);
    void sendCommand(String command, int maxTime, char readReply[])
      Serial.print(countTrueCommand);
      Serial.print(". at command => ?");
      Serial.print(command);
      Serial.print(" ");
      Serial.print("inside sendCommand loop");
      while(countTimeCommand < (maxTime*1))
        esp8266.println(command); //at+cipsend
        if(esp8266.find(readReply)) //ok
          found = true;
          break;
        countTimeCommand++;
      if(found == true)
        Serial.println("Found!");
        countTrueCommand++;
        countTimeCommand = 0;
      if(found == false)
        Serial.println("Fail");
      delay(500);
      found = false;
    The device fetches the senor node data, connects to internet but fails in responding to the TCP process
    Nov 2006
    Brazil
    8,630
    28,981
    41
    Blog Entries
    8
    Sorry to say, but you are not so clear with the words to make explicit what you meant, so once again:
    BTW, regardless of where each module is placed on the process, it is not so evident at which part of the data flow the problem is happening.
  7. #7
    Feb 2019
    31
    My architecture:
    there's a remote sensor node and a receiver node. The sensor node is communicating data to the receiver node with nRF24 module. Now the receiver node, along with nRF24 module also has a wiFi module (esp8266) with which it has to update the APIs.
    What I meant is that the receiver is displaying data sent from sensor node, it also connects to WiFi. But I feel the WiFi connection disconnects before uploading the data. Is it any delay related issue the code might have?
  8. #8
    Nov 2006
    Brazil
    8,630
    28,981
    41
    Blog Entries
    8
    Delays are always likely source of problem in programs, so I could bet that, yes. Anyway, your program does not check the connection status, ie do not try to reconnect (or report disconnection) in case this happens, so it is not possible to state that your feeling is correct or not.
  9. #9
    Feb 2019
    31
    Quote Originally Posted by andre_teprom View Post
    Keeping delay into consideration which part of the code would have caused it!
    •   AltAdvertisment
  10. #10
    Nov 2006
    Brazil
    8,630
    28,981
    41
    Blog Entries
    8
    Quote Originally Posted by anneshabaruah View Post
    At the sendCommand() routine, 500ms.
    Anyway you could find it by yourself.
