Results 1 to 7 of 7
10th February 2019, 17:11 #1
- Join Date
- Jul 2005
- Location
- Oakland
- Posts
- 410
- Helped
- 58 / 58
- Points
- 4,467
- Level
- 15
[ADS] Filter simulation with spiral inductor
im simulating a filter in ADS with two spiral inductors (coil) at the layer 3 and layer 4.
however, my layer 1 has RF traces and components, layer 2 is GND, layer 3 is a coil and layer 4 is another coil. i selected GND layer as slot. the rest of the layers are strip layers with finite copper thickness (not sheet metal). However, im not getting correlation between layout simulation and circuit simulation with "TL-multilayer".
i have a feeling that ADS not simulating inner layers well even if i define it as strip layer with finite copper thickness. Please let me know if my analysis is correct.
Advertisment
11th February 2019, 21:47 #2
- Join Date
- Nov 2001
- Location
- Turkey
- Posts
- 4,080
- Helped
- 1233 / 1233
- Points
- 28,273
- Level
- 41
Re: [ADS] Filter simulation with spiral inductor
Why did you select GND as slot ? Can you post the substrate illustration picture here ??
Advertisment
12th February 2019, 15:13 #3
- Join Date
- Apr 2014
- Posts
- 1,892
- Helped
- 758 / 758
- Points
- 12,125
- Level
- 26
Advertisment
13th February 2019, 12:02 #4
- Join Date
- Jul 2005
- Location
- Oakland
- Posts
- 410
- Helped
- 58 / 58
- Points
- 4,467
- Level
- 15
13th February 2019, 17:39 #5
- Join Date
- Apr 2014
- Posts
- 1,892
- Helped
- 758 / 758
- Points
- 12,125
- Level
- 26
I meant the schematic models (circuit simulation). You write that it doesn't agree to EM, so I wonder how you modelled this in circuit simulation (what models and values).
One possibly related issue: From what I remember, you had used MSUB parameters with almost perfect conductivity in a previous discussion.
13th February 2019, 19:40 #6
- Join Date
- Oct 2001
- Posts
- 4,785
- Helped
- 1413 / 1413
- Points
- 33,445
- Level
- 44
Any particular reason why did you use at one end of the inductor VIAS almost 3 times bigger than the VIAS on the other end?
Because they are in series, the DC current through all of them is the same, so will not help much (for this reason) to make bigger only some of them.
Advertisment
14th February 2019, 05:48 #7
- Join Date
- Jul 2005
- Location
- Oakland
- Posts
- 410
- Helped
- 58 / 58
- Points
- 4,467
- Level
- 15
Please login
