Results 1 to 7 of 7
    Member level 3
    Points: 3,056, Level: 13
    Dec 2004
    67
    3,056
    13
    Good wire for small antenna
    i looking for the best wire to build wire antena like quadrifilar etc.
    i want the best reference for solid wire because the ones i found are too soft
    thanks
    •   AltAdvertisment
    Points: 254,022, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,264
    254,022
    100
    Re: Good wire for small antenna
    Metal tubes are the usual choice.
    Member level 3
    Dec 2004
    67
    3,056
    13
    But i’m looking for diameter about 1mm
    •   AltAdvertisment
    Points: 33,573, Level: 44
    Oct 2001
    4,799
    33,573
    44
    I assume the antenna is dedicated for high frequencies. In this case the best wire would be silver plated copper wire.
    https://www.wires.co.uk/acatalog/cu_sp.html
    Member level 4
    Points: 761, Level: 6
    Feb 2017
    73
    761
    You can use RG402 coax which has 1.3mm core diameter.
    Member level 3
    Dec 2004
    67
    3,056
    13
    Thanks Vfone for your answer , i tried to use this wire .
    •   AltAdvertisment
  7. #7
    Points: 34,182, Level: 45
    Dec 2004
    New England, USA
    4,807
    34,182
    45
    by small antenna, do you mean "electrically small"?
    If so the resistance in the wire will be CRITICAL if you want it to radiate any power at all. I have even used solid silver wire in certain applications, since silver has the lowest resistivity
