sqx
If I'm correct, if I put a electric current dipole along X axis, and a magnetic current dipole along Y axis (both sources are at the origin), I think I'll have an antenna that is almost only propagating towards the upper space in the coordinate system. If we only observe Z axis, the two fields will be superposition for positive Z axis, and cancellation for negative Z axis.
First question: Am I correct about this condition?
Second question: Can I make such an antenna by placing a wire along X axis and a small loop along Y axis to create such a condition and get a single direction antenna without a reflector plate?
