Results 1 to 6 of 6
    Full Member level 6
    Points: 4,410, Level: 15
    Externet's Avatar
    Jan 2004
    Mideast US
    376
    4,410
    15
    Circuit to detect presence of a single RF frequency ?
    Hi.
    -Detection here not meaning to demodulate-
    Detection as to know if 10.7MHz ± 100KHz is present on an existing receiver circuit node, to turn a LED on. How should be done ? Any dedicated IC or portion of such that does/could do it ?
    Abolish the deciBel !
    •   AltAdvertisment
    Points: 28,273, Level: 41
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,080
    28,273
    41
    Re: Circuit to detect presence of a single RF frequency ?
    A simple amplifier then a ceramic 10.7MHz filter following a amplifier+comparator will turn-on the LED.
    Even an OPAMP may work with a appropriate circuit combination.There are many choices..
    •   AltAdvertisment
    Advanced Member level 2
    Points: 3,727, Level: 14
    Nov 2013
    570
    3,727
    14
    I don't know how can a LED turn on with such a high frequency, I think a mixer + 10MHz oscillator + low-pass filter + amplifier rather capable.
    SA612 could be good because it contains mixer and oscillator.
    "Try SCE to AUX." /John Aaron/
    •   AltAdvertisment
    Points: 76,741, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,551
    76,741
    67
    Use a PLL and connect the LED to the lock indicator. By changing the VCO components you can set the center frequency and by changing the loop components you can set the lock bandwidth.
    Member level 3
    Points: 428, Level: 4
    Aug 2018
    64
    428
    HMC1120 from analog can do the work. It is may be over-qualified.
    https://www.analog.com/media/en/tech...ts/hmc1120.pdf
    You may need to put a bandpass filter to just detect the 10.7MHz signal.
    •   AltAdvertisment
    Points: 34,039, Level: 45
    Dec 2004
    New England, USA
    4,789
    34,039
    45
    Quote Originally Posted by BigBoss View Post
    i would modify this...ceramic filter, amplifier with 15 db gain at 10.7 MHz, another ceramic filter, then a schottky diode detector. The DC output of the detector can drive a comparator with a TTL output, that you could add a resistor limited LED to.
    by using TWO ceramic filters...you can get almost 60 dB rejection of other frequencies.
