Results 1 to 2 of 2
    Newbie level 1
    Points: 18, Level: 1
    Feb 2019
    18
    Marconi 2955B Power Meter Fault
    Hello I have a Marconi 2955B with a RF Power meter problem,
    On a chunks of frequencies it reads the power level low and 25KHz up it reads ok , I have checked my power source and it is fine against two other meters so it is a issue with the 2955B,
    It will be ok for a few MHz then will be bad for like 10MHz , It reads the power correct for a few seconds then it re calculates again and reads low 50W becomes 33W
    Any help would be great, I do have another 2955B as wonder i i could juts swap the dummy load of all the plug in boards to locate the fault?
    ok Many thanks
    •   AltAdvertisment
    Points: 51,225, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,574
    51,225
    55
    Re: Marconi 2955B Power Meter Fault
    Intermittent problems are the most frustrating.
    Start by troubleshooting things that are easy to do, or easy to check, or easy to put back the way they were, or are not troublesome if you do something wrong.
    Swapping dummy loads seems like an easy and obvious thing to try. Watch for obvious behavior that could indicate a problem. Watch power supply voltage, tap components, examine with a magnifier for fractures in solder joints and pcb traces. Watch whether the problem occurs after the unit warms up or while it is cold.
    33W is two-thirds of 50W. Is the drop always to 2/3 of initial reading?
