Page 1 of 2 1 2 LastLast
Results 1 to 20 of 29
    Newbie level 5
    Points: 58, Level: 1
    Feb 2019
    9
    58
    RF Detector not detecting cellular phones
    Hi all,
    I was hoping somebody can tell me why the below rf detector is not picking up any cellular phone signals? I am using through hole components and have soldered everything onto a CNC made PCB boards, keeping all tracks as short as possible (see image). I have no problem detecting 27Mhz, 40Mhz (wireless home phone), 466Mhz (walkie-talkie) but I am getting nothing from 2.4Ghz WiFi or 3G/4G frequency(s) even when holding the phone literally a few millimeters next to the antenna. I have ordered a high frequency, wideband LNA monolithic amplifier to try boosting the signal before rectification eventhough I think a cell phone transmitting at at least 1 watt when attempting to make a connection immediately next to the pickup antenna would not need a LNA pre-amp stage. Curious to hear some of you more experienced RF guys input!!!
    Points: 25,005, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,790
    25,005
    38
    Re: RF Detector not detecting cellular phones
    I don't think that diode is appropriate for 2GHz.
    After a closer look, maybe it's ok. But I would look carefully at your layout.
    Points: 31,244, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,589
    31,244
    43
    I guess the diode may work up to 1GHz but a signal amplifier ( even a simple one with a single transistor) will help to detect the signal strength.
    The diode is not appropriate at all for 2.4GHz..
    Newbie level 5
    Feb 2019
    9
    58
    Thanks for the response guys!
    Why would the diode be inappropriate for 2Ghz? It has 2pF junction capacitance. Plus, others seem to be using it successfully for fine tuning their 2.4Ghz RC transmitters. See link.
    https://www.rcgroups.com/forums/show...h-meter-for-rc
    4G carrier frequencies in my country are anywhere between 850Mhz and 2.6Ghz so I am thinking I should be picking up something. I think I should mention that I have also tried a pair of BAT62 diodes but on the breadboard circuit, not PCB and that also had no issues detecting 40Mhz and 466Mhz but not the cell phone.
    Points: 34,386, Level: 45
    Dec 2004
    New England, USA
    4,823
    34,386
    45
    "It has 2pF junction capacitance."
    You do realize that 2 pf is a HUGE amount of capacitance at 2.4 GHz, right?
    Get a diode with 0.2 pF.
    Also, does your PC board have a ground plane on the backside?
    I would also change it to a single diode.
    Points: 34,596, Level: 45
    Oct 2001
    4,937
    34,596
    45
    On the net I found another schematic, also using 1N5711 diode, but followed by an amplifier.
    http://www.techlib.com/electronics/cellhelp.htm
    This schematic was designed by Charles Wenzel, one of the biggest guru in RF.
    Using the spice model offered by ST for 1N5711 and using LTspice, I see that 1N5711 works fine at 2.4GHz AS a detector.
    Remove the 50 ohms resistor at the input of your detector, and probably your circuit will work just fine.
  7. #7
    Newbie level 5
    Feb 2019
    9
    58
    "You do realize that 2 pf is a HUGE amount of capacitance at 2.4 GHz, right?"
    Obviously not big enough to stop a 2.4Ghz FlySky FS-HF030 RC transmitter. See video below. I do mention in the same post that I have tried a pair of BAT62 diodes that are advertised, in the datasheet, as "Low barrier diode for detectors up to GHz frequencies" and have capacitance of 0.35pF (typical) but that too produced no results when trying to detect my cell phone (iphone 6s on 4G network). Neither did it work in detecting the 2.4Ghz WiFi signal from my router.
    I had forgotten that I had a 2.4Ghz RC transmitter and tried that and sure enough the rf gets detected. It is based on the A7105 chip and uses FSK/GFSK modulation. This to me at least proves that the circuit works at least up to the 2-3Ghz band, with the highest currently operational 4G frequency being 2.6Ghz, only 200Mhz above 2.4Ghz. I thus cant help but wonder if is something to do with the short cell phone bursts? All three devices I demonstrate in the video below have a continuously emitted RF signal but I am not sure if cell phones transmit the same way.
    "Also, does your PC board have a ground plane on the backside??"
    I would say so, see attached image.
  8. #8
    Points: 265,300, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,357
    265,300
    100
    Unfortunately the ground plane is unconnected.
  9. #9
    barry's Avatar
    Mar 2005
    California, USA
    4,790
    25,005
    38
    Lol.
    And 2pf at 2.4 GHz is not HUGE, unless you consider 30 ohms HUGE.
  10. #10
    Oct 2001
    4,937
    34,596
    45
    Quote Originally Posted by M84AB3 View Post
    As I mentioned, seems that the detector works at 2.4GHz. I see that you didn't remove the 50 ohms at the input. That will improve a bit the sensitivity of the detector. You can replace that resistor with a 0.1uH RF choke (the same as in the 2nd schematic in link that I posted above).
    Cell phones in 2G mode transmit bursts with duty cycles varying between 1/8 and 4/8. In 3G and 4G modes there is a continuous transmission during a call.
    In cell phones, their output power vary from -50dBm to about +24dBm in 3G and 4G and up to +33dBm in 2G. So the power is not constant during a call as in your cordless phone or RC transmitter.
  11. #11
    Points: 15,137, Level: 29
    Apr 2014
    2,353
    15,137
    29
    Quote Originally Posted by vfone View Post
    But this layout is far from ideal. By shrinking the layout and using proper RF layout technique, the detector could be much more sensitive.
  12. #12
    Oct 2001
    4,937
    34,596
    45
    Totally agree, a good PCB would help. And is not impossible because seems that have access to a PCB milling machine, which makes the job easier.
    But even the best PCB design would not help if a relative high impedance detector input is shortened to the ground with a 50 ohms resistor.
  13. #13
    Newbie level 5
    Feb 2019
    9
    58
    I did remove the 50 ohm resistor by cutting the bottom lead with wire cutters. It is not obvious in the video. If the 4G transmission is continuous then why am I not able to pick it up with the antennas literally touching one another? If it works for 2.4Ghz RC transmitter, I don't see why it wouldn't work for a cell phone.
    Quote Originally Posted by volker@muehlhaus View Post
    As I do have a CNC machine I will go all out SMD on this one and see what results I get. I have ordered a few MGA-86563 MMICs to use as the front-end LNA.
  14. #14
    Points: 81,871, Level: 69
    Apr 2014
    16,622
    81,871
    69
    I see the "ground plane" problem much more important than the SMD/THM problem.
  15. #15
    Newbie level 5
    Feb 2019
    9
    58
    Can you please explain in a little more detail? That statement alone doesn't tell me much.
    By ground plane I assume you mean something as described here under the "Microstrip" section.
  16. #16
    Apr 2014
    16,622
    81,871
    69
    as stated in post#8:
    It doesn´t help to generate a large area of "unconnected" copper. You need to connect it to system_GND and need to use it as GND_Plane.
  17. #17
    Newbie level 5
    Feb 2019
    9
    58
    Alright, I have redone the PCB with all of the GND points connecting to the large piece of copper. I have also used BAT62 diodes instead of 1n5711 as they are officially rated for GHz and have even lower capacitance than 1n5711 diodes. Unfortunately, the circuit is now even LESS sensitive, actually SIGNIFICANTLY less sensitive than the original one I built (depicted in my first post), without a proper ground plane. How or why would this be? There are no issues (shorts or wrong connections) with the PCB, I have checked like 10 times. It is worthwhile mentioning that the original PCB actually started picking up 4G (only data) transmissions, and quite well I must say, once I placed a piece of copper/metal sheet underneath it with a piece of paper acting as a dielectric. It would however not respond to WiFi or Voice calls.
ID:	151176Click image for larger version.
  18. #18
    Points: 83,881, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,806
    83,881
    70
    From an RF point of view, that is a complete disaster. You really need to understand the concept of wavelengths then closely look at the tracks around the RF front end. The track carrying signal from the antenna is almost as long as the antenna itself. Why do you have five capacitors in parallel?
    Also consider the antenna is hardly wide bandwidth and you are asking for a detector covering at least 27MHz to 2,400MHz.
    A full schematic of your board would help with diagnosis.
  19. #19
    Newbie level 5
    Feb 2019
    9
    58
    There is no need to be condescending. I am here because I am not an "expert" in RF design and am trying to learn. Calling something a disaster without providing constructive feedback is hardly helping. What makes you think I do not understand the concept of wavelengths? Do you think my CNC machine was a christmas present and here I am slapping together "some circuit"?
    I understand that this is by no means an efficient design, and it should really be all SMD but I am not designing some ultra sensitive 5G receiver and I would have thought that for close range (close to the transmitter) it would pick up something across the major frequencies.
    This Antenna came off of a GPRS Shield v1.0 running a SIM900 module and works on the 850/950/1800/1900 bands. 850Mhz to 1900Mhz seems pretty "wide" to me. Additionally, it works "exceptionally well" at 40Mhz and 466Mhz. Similar to how an AM wavelength is in the range of 300 meters but you can still hear it on your radio without a 150m or a 75m antenna attached to your house I would have thought I would pick up at least something THAT close to the transmitting source.
    The schematic is exactly as depicted in my first post, minus the 50ohm resistor and the 1n5711 diodes have been replaced with BAT62 diodes. In addition to the 10pF and 1000pF capacitors I have added 100pF, 10nF and 100nF to try and see if it makes any difference with different carrier frequencies. The rest of the schematics is less important as it is just an op-amp (CA3130) with 100 gain that picks up the signal once it has already been rectified, in essence its just a DC voltage amplifier.
  20. #20
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,806
    83,881
    70
    My apologies, it wasn't meant to be condescending.
    The point I was making is that at high frequencies, because the wavelength is shorter, the effect of wiring length becomes critical. Taking your design, if the antenna is orientated as in your photographs, you have almost a quarter wave of 'backwards' track picking up almost the same signal as the antenna. The effect could be signal cancellation but the zig-zag wiring would make it hard to predict exactly how much cancellation might occur. At best you would get a very variable coupling response, it could be almost nothing at some frequencies up to total at others. SMD has little to do with it but it does help to make wiring lengths predictable. I have units here that do not use SMD but operate at 2.4GHz quite happily.
    An antenna, especially one that probably has a coiled element inside it, has a complex 'gain' response and directivity pattern across different frequencies. It may work well at some frequencies but reject others. Because it is rated at 850MHz and at 1900MHz doesn't mean it works equally well between them. In all probability, it has 'traps' or gaps in the element so it peaks at specific frequencies. It should work against a ground plane anyway so for best results it should be at 90 degrees to the ground plane on the PCB. (facing the same way as the components)
    You only need one of the parallel capacitors and the value isn't critical because in theory there is a DC voltage there. A single 1nF capacitor should be sufficient and adding more has no significant effect on frequency response.
    I would still like to see your schematic. I wonder if you are seeing an effect that has nothing to do with the antenna or detector diodes at all. If I follow the component layout and tracks from your photographs, the biasing is wrong on the CA3130 and it can't possibly amplify. What you might be doing is measuring RF pickup on the amplifier pins rather than through the antenna. RF leaking into the IC might shift it's internal voltages and give the impression it is working, although not correctly.
