Results 1 to 15 of 15
    Full Member level 5
    Points: 1,667, Level: 9
    Sep 2016
    261
    1,667
    9
    Ground Connection with PCB
    In this PCB,the copper pour will be connected to ground(Earth point from power supply).
    But while pouring the copper all the parts are not filled with copper due to tracks.
    If the circuit is big means when pouring copper for ground means it filling on outer side of track only.
    Is this is correct or have to change something for connecting earthing.
    Points: 77,432, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,677
    77,432
    67
    Re: Ground Connection with PCB
    None of the tracks are grounded but I suspect they should be. When you did the copper pour, did you specify the ground node should be connected to it?
    •   AltAdvertisment
    Points: 70,890, Level: 64
    Apr 2014
    14,505
    70,890
    64
    Iīm not sure: Are you talking about the blue layer or the red layer?
    If blue layer:
    If you want the copper pour to be connected with GND then signal_name(schematic) needs to be equal to polygon_signal_name.
    If you want to copper fill the space between the traces (even if not connected to GND signal) then
    * press INFO and click on the polygon outline. An info window apprears. Check ORPHANS. Close the info window. Perform a RATSNEST.
    Full Member level 5
    Sep 2016
    261
    1,667
    9
    If blue layer:
    This is working fine.If the +5VDC's NEGATIVE supply have to connect with copper pouring means how to do it..?
    The earthing have to connect with mounting holes and +5VDC's NEGATIVE supply have to connect with components GND pin
    Outer Copper pouring is connected
    •   AltAdvertisment
    Apr 2014
    14,505
    70,890
    64
    Hi
    * +5VDC's NEGATIVE supply --> Whatīs the exact SIGNAL NAME?
    * copper pouring --> Whatīs the exact SIGNAL NAME of this POLYGONE?
    Both SIGNAL NAMES need to be the same. Thatīs all.
    Full Member level 5
    Sep 2016
    261
    1,667
    9
    Connecting +5VDC's NEGATIVE supply with earth is not an issue..?
    For learning i'm asking..
  7. #7
    Points: 28,670, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,535
    28,670
    41
    Blog Entries
    If you are doing a single layer PCB, you can reach surrounded regions by skipping over obstacles e.g adding a 0R0 resistor from the outside GND plane inwards to there.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   AltAdvertisment
  8. #8
    Apr 2014
    14,505
    70,890
    64
    Depends on what you want.
    If you want a floating supply (wrt EARTH) then you should not connect them.
    With SMPS itīs common practice to connect ouput_GND with EARTH via a (safety) capacitor to suppress HF (common mode) noise.
  9. #9
    Full Member level 5
    Sep 2016
    261
    1,667
    9
    I'm using SMPS to power my circuit.
    Shall I use capacitor between Earth and GND in SMPS's output terminal itself or have to place the capacitor in PCB..?
  10. #10
    Apr 2014
    14,505
    70,890
    64
    there is no general answer. It depends on a lot of parameters.
    (Your country's regulations, safety standards, SMPS circuit, noise, ...)
    In worst case the SMPS is already earthed and with a second earthing you generate a loop.
  11. #11
    Full Member level 5
    Sep 2016
    261
    1,667
    9
    shall I create two polygons..?
    1.To connect +5V's ground supply.
    2.Another to create an copper pour around the track and shall i connect it to earth..
  12. #12
    Apr 2014
    14,505
    70,890
    64
    My personal answer: I donīt know.
    I donīt know why you want to use EARTH at all. What is it good (or used) for?
    I donīt know your requirements.
    I donīt know your complete circuit, wiring...
    I donīt know the regulations of your country.
  13. #13
    Junior Member level 2
    Points: 2,236, Level: 10
    Sep 2007
    23
    2,236
    10
    Have you routed the ground also as tracks?
    •   AltAdvertisment
  14. #14
    Newbie level 1
    Points: 667, Level: 5
    Aug 2015
    667
    When i see your PCB, i don't see any necessary extra ground connection. But It might be useful covering ground plane.
  15. #15
    Advanced Member level 3
    Points: 9,513, Level: 23
    cyberrat's Avatar
    Jun 2001
    In the sewers of the U.K.
    883
    9,513
    23
    What does this board do?
    It looks like all it's doing is powering an LED? I see no output.
    Please do not PM me questions that are better asked in the PCB forum :)
