However, the pole analysis does not help in deriving the stability criteria at expression (4.23)
instability is when root crosses the 'z=1' circle bound.
Ok, then setting equation (4.12) to 0...
No, at this equation you set the Z variable at the left side to '1', which cancel the remaining constant '1' at the right side.
