Results 1 to 3 of 3
19th January 2019, 04:40 #1
- Join Date
- Oct 2017
- Posts
- 57
- Helped
- 0 / 0
- Points
- 529
- Level
- 4
Calculating Max deviation in C
I am trying to implement above equation mentioned in link. I am using pic16F1938 for coding.
https://zenatix.com/current-and-volt...nter-measures/
Can someone help me or suggest me formula to calculate Max-deviation In c
All the variable declared as Unsigned int. In the mentioned example for unbalance current how to keep percentage limit.
Advertisment
19th January 2019, 07:07 #2
- Join Date
- Feb 2017
- Location
- Philippines
- Posts
- 64
- Helped
- 5 / 5
- Points
- 779
- Level
- 6
Re: Calculating Max deviation in C
If it's just C coding, you could place each sample in an array and create a function using 'for-loop'.
[URL]https://www.programmingsimplified.com/c/source-code/c-program-find-maximum-element-in-array[\URL]
Advertisment
19th January 2019, 07:09 #3
- Join Date
- Oct 2017
- Posts
- 57
- Helped
- 0 / 0
- Points
- 529
- Level
- 4
I have implimented code considering the example. But in the example it not mentioned in which 2 phase unbalance has occurred.
can someone guide me here.
Code:unsigned int Max_Current=0; unsigned int Min_Current=0; unsigned int Unbalance_limit=10; unsigned int Max_Deviation=0; unsigned int Percentage_Unblance=0; void Unbalance_Check() { Imean_Current=(Rph_Current+Yph_Current+Bph_Current)/3; if((Rph_Current>Yph_Current)&&(Rph_Current>Bph_Current)) { Max_Current=Rph_Current; }else if((Yph_Current>Rph_Current)&&(Yph_Current>Bph_Current)) { Max_Current=Yph_Current; }else if((Bph_Current>Rph_Current)&&(Bph_Current>Yph_Current)) { Max_Current=Bph_Current; }else if((Yph_Current
Unbalance_limit) { CRUnblance_Flag=1; }else { CRUnblance_Flag=0; } }
Please login
