Results 1 to 6 of 6
    Newbie level 3
    Points: 74, Level: 1
    Guns29's Avatar
    Oct 2018
    74
    PLC software for network access
    Hello!
    I ask for help to solve the problem that happened in our factory.
    We brought new equipment for the job, it is automated. we will use with PLC as one of its main components. Since PLC is controlling an industrial machine as a stand-alone computer.
    And the fact that connect it remotely using the server architecture, which is part of the SCADA system.
    In this case, they are controlled by the SCADA and HMI software packages running on the servers.
    What software can I do with it?
    •   AltAdvertisment
    Points: 252,712, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,020
    252,712
    100
    Re: PLC software for network access
    Most PLC systems have either built-in or optional network interfaces and provide different protocols as server or client.
    What is your PLC system, what want you exactly to achieve?
    •   AltAdvertisment
    Full Member level 5
    Points: 1,648, Level: 9
    Aug 2016
    255
    1,648
    9
    Every PLC system has a unique software that runs it. Softwares are not interchangeable between PLC systems by different manufacturers. So you have to have the software that runs the PLC that you have.
    If we know the brand of PLC (and the model) then we can advise accordingly.
    --Akanimo.
    •   AltAdvertisment
    Newbie level 3
    Guns29's Avatar
    Oct 2018
    74
    Hello to all who answered. I apologize that I described the problem so ridiculously, I did not know what I was doing in a panic. We have at the plant are machines running PLC system. Coming expansion and increase technology and I was instructed to configure the network to receive data from all the PLC systems remotely on one computer and manage data. Since the monitoring and reception of data in parallel will occur in another country.
    What method can I solve this?
    Points: 70,792, Level: 64
    Apr 2014
    14,484
    70,792
    64
    I wonder: did you read post#2 and post#3?
    •   AltAdvertisment
    Junior Member level 1
    Points: 1,919, Level: 10
    Jan 2009
    Mandalay
    16
    1,919
    10
    Modbus ,RS 485 and later plc use profinet
