eagle1109
Full Member level 6
- Joined
- Nov 20, 2014
- Messages
- 390
- Helped
- 4
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Saudi Arabia
- Activity points
- 5,911
This is not new problem to me, I encounter power lines come off when desoldering something from the PSU.
Maybe I put the soldering iron a several times on the pin to melt the soldering wire. But that shouldn't happen on commercial grade Dell PSUs! I mean the PCB should handle the temperature of the soldering iron.
What should I do? Should I just connect this part by putting some soldering wire? I think that would solve the problem, but I'm afraid of the SMD resistor part, I don't know if I could connect its part to the soldering process, but I guess its end would get connected with the soldering wire I put in that area.
Also, is this a burnt on this small HFT?
