Results 1 to 11 of 11
    Full Member level 2
    Points: 1,473, Level: 8
    Nov 2014
    Saudi Arabia
    139
    1,473
    8
    Is there a safe way to fix this scratch on the hot side of PSU?
    This is not new problem to me, I encounter power lines come off when desoldering something from the PSU.
    Maybe I put the soldering iron a several times on the pin to melt the soldering wire. But that shouldn't happen on commercial grade Dell PSUs! I mean the PCB should handle the temperature of the soldering iron.
    What should I do? Should I just connect this part by putting some soldering wire? I think that would solve the problem, but I'm afraid of the SMD resistor part, I don't know if I could connect its part to the soldering process, but I guess its end would get connected with the soldering wire I put in that area.
    Also, is this a burnt on this small HFT?
    Points: 80,586, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,205
    80,586
    69
    Re: Is there a safe way to fix this scratch on the hot side of PSU?
    Dell PSUs are no better or worse than every other make.
    Top picture: not much you can do to restore the original copper, I think I would run a wire link between adjacent solder pads along the track and angle it to touch the SMD resistor. You can get PCB repair kits and glue new copper down but it's a lot of effort just to make it cosmetically better.
    Lower pictures: the solder between the third and fourth pins from the top looks pitted as though it has arced at some time. The board seems to have some residue on it which may have become conductive at some time and bridged the pins. All you can do is clean it thoroughly and resolder the joints to make sure no 'spikes' are left that might narrow the gap.
    If the board is used in damp conditions, after repair, spray it with HPC or some similar conformal coating to keep moisture out.
    Points: 16,730, Level: 31
    Nov 2012
    3,073
    16,730
    31
    The copper film is stuck to the base plastic with glue; this appears to be fiber-glass bonded with epoxy. The copper foil is stuck with epoxy glue. This is a thermoset polymer and bonds well with metal.
    However, no bond can stand excessive heat. But you can fix it with a drop of epoxy glue; there are some that set fast. It may not look as new but it may work as well.
    About the second (and third pic): YES. you need to remove and clean and check and resolder. A post mortem will be in order.
    Points: 52,361, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,836
    52,361
    55
    I used the CircuitWorks silvery conductive pen and silver epoxy. They stuck to PV cells when I needed to attach wires but I vaporized the solderable traces with excess heat.
    An auto parts store may have a repair kit for defogger grids. Copper particles suspended in solvent. Examine the packages carefully because I found some had dried out in the tiny bottle.
    Advanced Member level 1
    Points: 3,711, Level: 14
    May 2012
    499
    3,711
    14
    The first picture the track has lifted, I would solder a piece of wire in its place, the third picture the solder joints have burnt due to very high peak currents and the second from the bottom joint looks open circuit, I would remove the component connected to these pins, check and clean or replace and refit.
    Full Member level 2
    Nov 2014
    Saudi Arabia
    139
    1,473
    8
    Quote Originally Posted by c_mitra View Post
    Could you send me a link in aliexpress for this kit?
    Quote Originally Posted by BradtheRad View Post
    Well, in my country and specifically in the city I'm in, I don't think there are repair shops that could have professional repair tools. I always buy anything from Aliexpress. So I would appreciate it if you send me links for the stuff you told me about.
    Quote Originally Posted by pjmelect View Post
    The 2nd and 3rd pictures are for the same spot, I just took a picture from very close and little far for more observation to the area because that is a high frequency transformer located along the other high frequency transformers between the high / low voltage sides of the PSU.
    I have another question:
    I want to buy thermal pads for the power mosfets, which one should I get? I found a conductive one on aliexpress:
    https://www.aliexpress.com/item/100x...b-a04d5d085c8c
    Would this one work?
  7. #7
    Apr 2011
    12,836
    52,361
    55
    Quote Originally Posted by eagle1109 View Post
    Aliexpress lists it but 'no longer available'. (US $44.80) It isn't flux and it isn't thermally conductive paste. Its formulation must be a trade secret because it worked like magic so I could attach wires to solar cells, headphone transducers, and inside a Honeywell calculator. (I only paid $12 for the pen. I'm not sure I'd pay $44.80.)
    https://www.aliexpress.com/item/Circ...874633569.html
    Aliexpress lists defogger grid repair kits. Varying prices. Here is one for US $7.49:
    https://www.aliexpress.com/item/LocB...864938550.html
    My bottle had liquid containing copper particles similar in size to fine sand. There's a question how suitable it is for miniaturized electronics.
    Because I found a few dried out glue bottles in the auto store, it might pay you to ask them to examine the kit they send you, to make sure the glue is good.
  8. #8
    Nov 2012
    3,073
    16,730
    31
    There are several - this one is one example: high viscous 5 seconds quick to dry metal machine glass fiber ceramic hard plastic epoxy resin adhesive super AB glue
    Silicones are plastics (polymers) and they are good conductors of heat (compared to other plastics and do not compare them with metals). Use the thinnest one that will meet your requirements.
  9. #9
    Member level 5
    Points: 958, Level: 7
    Aug 2016
    88
    958
    7
    1st pic: If you want faster repair, just add jumper wire replace the broken line, it should be fine. Using repair kits need some skills.
    2nd pic: It's true heat marks, possible got bad solder already. Suggest to solder touch-up that pins.
    Some repaire tips https://elex518.blogspot.com/
  10. #10
    Full Member level 2
    Nov 2014
    Saudi Arabia
    139
    1,473
    8
    Yep the name is long, I think it's some sort of special glue for PCB repairs, am I right? Is it similar to; like, super glue, or it may contain conductive stuff for the conductivity of the copper path of the PCB?
    In regard to the thermal pads, yes I think anyone would work as it should be a silicon. Yes thank you for the tip.
    Quote Originally Posted by i200yrs View Post
    1. You're right I better repair it with a wire or some solder wire and that's it.
    2. That black color is what I think is a spark! It could be the cause of failure of that PSU.
  11. #11
    Full Member level 2
    Nov 2014
    Saudi Arabia
    139
    1,473
    8
    Got this thermal pad recently
    I think it's a bit thick, but anyway, is it suitable for PSU power mosfets?
