Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
  1. #21
    Advanced Member level 1
    Points: 2,170, Level: 10
    baileychic's Avatar
    Aug 2017
    420
    2,170
    10
    Re: Need help in LED controlling
    #betwixt
    Ref voltage is connected to INV+ or INV- pin in your circuit ?
    •   AltAdvertisment
  2. #22
    Points: 76,699, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,547
    76,699
    67
    Depends on the power control circuit, it will work both ways, one will make the comparator output high when more than two solenoids active, swap them and the output will go low instead.
    •   AltAdvertisment
  3. #23
    baileychic's Avatar
    Aug 2017
    420
    2,170
    10
    Here is the circuit that I made referring betwixt's circuit. All resistors connected to switches are 10k. There is a slight problem. If I don't use 100u then circuit doesn't work because the switch circuit's output voltage fluctuates a lot doe to ground connected to neutral.
    If I use 100u then there is slight problem in simulator that is when 3rd lamp is turned ON then it initially turns ON for 2 sec and then all lamps turns OFF.
    Edit:
    Changed the circuit a little. SVCv2.1. Both SVCv2 and SVCv2.1 works.
    •   AltAdvertisment
  4. #24
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,547
    76,699
    67
    I anticipated the voltage drop problem but without a specification for the solenoids it is difficult to see how much it is likely to be. However, to mitigate the problem I used a comparator and increased the supply voltage. Increasing the voltage makes the voltage drop in the wiring less significant. You have again dropped the supply and used an op-amp. If anything I would have done the opposite and run the comparator and resistor chain from a higher voltage.
    Nevertheless, I think you would agree it can be much simpler than originally proposed!
