Results 1 to 4 of 4
    Advanced Member level 2
    Points: 3,989, Level: 14
    Apr 2010
    Chennai,India
    615
    3,989
    14
    How to fix the pop up message in windows script host ??
    Hi everyone,
    i got pop up for every time while booting my system,windows script host pop not able to disable. How to fix this issue.
    https://imgur.com/a/yD7QU1U
    i opened this file in .vbs format.
    Set WshShell = CreateObject("WScript.Shell")
    WshShell.Run chr(34) & "C:\Users\kabalee\AppData\Roaming\vol.bat" & Chr(34), 0
    Set WshShell = Nothing
    kindly help to fix this issue.
    kapil
    Points: 9,792, Level: 23
    d123's Avatar
    Jun 2015
    1,726
    9,792
    23
    Re: How to fix the pop up message in windows script host ??
    Have you looked at any of the pages linked below? I typed this into Google: "windows error code 80070002 in script host"
    I don't know if they'll help but they might be useful in diagnosing (and solving) the issue:
    How to Fix Windows Script Host Errors on Startup
    Windows Script Host Error Code 80070002
    How to Fix windows script host error Code 80070002
    Random windows script host error
    The first link looks sensible, but then the second is Microsoft so must be reliable. Hope you've already solved it.
    Newbie level 1
    Points: 15, Level: 1
    Mar 2019
    15
    When all else fails, just restart your computer. You can also clean up computer errors with registry software. I myself have less time on my hands now, so I prefer (gbwhatsapp for android) to have this problem taken care of automatically if I can.
    Oh, but there is a chance you may have to update your Java program or repair it. That also is another thing that the registry fix software does for you. Otherwise, you can go to the Java site itself.
    Points: 43, Level: 1
    Nov 2019
    London
    7
    43
    You can solve this problem by run a system file checker, install a Microsoft safety scanner in windows 10 and by clean boot process.
