venkates2218
Full Member level 6
At initial PIN 32 will be in high state.when the switch is turned ON an sequence will execute in the controller and the LED connected with the switch have to glow which indicate the sequence is turned ON.
But when the SWITCH is TURNED ON the LED not glowing and their is no action in the controller also.If I checked the controller without the LED part means working fine.
How to solve this issue..?
