Results 1 to 4 of 4
    Advanced Member level 2
    Points: 3,726, Level: 14
    Jan 2012
    Italy
    592
    3,726
    14
    instrumentation amplifier with wide differential input
    Dear Friends
    I am designing instrumentation amplifier with differential input voltage equal to 400 mv, I used a source degeneration resistor to increase this range. do you think it is good range?
    Can you please suggest me some of the available commercial instrumentation amplifier in order to compare
    thank you very much
    •   AltAdvertisment
    Points: 38,027, Level: 47
    Mar 2008
    USA
    6,143
    38,027
    47
    Re: instrumentation amplifier with wide differential input
    If you know output signal range desired and gain,
    you get the differential input range.
    Distinguish between "amplify clean" and "tolerate,
    with loss of fidelity" regarding the differential input
    range, and do not neglect the common mode bind
    which may change as you attempt to raise signal
    range. The internal amps each have their limits and
    the A=2 front end amp particularly can be a problem
    for high input levels, clipping at its output.
    •   AltAdvertisment
    Jan 2012
    Italy
    592
    3,726
    14
    Thank you free,
    I am getting +-400mV linear and clean differential level, only have a problem when the gain is set to unity I can see clipping, otherwise it is working fine from Gain = 2 and more, soon I will show you the result graphs,
    do you think it is good result even when the amp is not working with unity gain ?
    thank you again
    •   AltAdvertisment
    Points: 40,146, Level: 48
    LvW's Avatar
    May 2008
    Germany
    5,749
    40,146
    48
    Junus2012, you want to discuss the prioperties of a circuit - without showing the circuit.
    Do you really expect to get a comprehensive answer?
