Results 1 to 12 of 12
    Full Member level 2
    Points: 1,380, Level: 8
    Sep 2014
    132
    1,380
    8
    OP amp output oscillating
    Dear All,
    Here's my circuit
    When input voltage gets to 47mV LM358P OP AMP U1:A strengthens that voltage by 48 times and OP AMP U1:B compares it against reference voltage 2.18V and turns on output to PIC digital input. I get around 3.75V to the pic input pin. According to PIC12F683 datasheet min 2.0V needed to recognize it as HIGH state. So that is ok and it actually works just fine on breadboard.
    However I decided to change the OP AMP to LM2902N and end up in troubles. Around 47mV +-~3mV if connected to pic input it starts to oscillate. If it is not connected anywhere it will not oscillate. Around 43mV it is low and around 50mV it is high stable. I have tried positive feedback resistor in U1:B but that didn't help. Please help me to understand why this type of OP AMP is not working and how could this be fixed?
    Thank you in advance
    Advanced Member level 2
    Points: 3,417, Level: 13
    Nov 2013
    511
    3,417
    13
    Re: OP amp output oscillating
    Maybe you have higher noise? Are you sure it is oscillation, not supply/ground coupled signal or something else?
    Could you tell something about the waveform you experienced (freq,amplitude,shape)?
    "Try SCE to AUX." /John Aaron/
    •   AltAdvertisment
    Full Member level 2
    Sep 2014
    132
    1,380
    8
    It is noisy as well and oscillating.
    Here is the oscillating:
    Here is the noise:
    Points: 250,686, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,641
    250,686
    100
    The 4 MHz "noise" can't be generated by a slow OP, it must be sourced from the ĩC or other circuit parts. Seeing so large interference signals raises doubts about proper circuit layout, particularly appropriate ground connections.
    A you sure that the input voltage, Vref and supply voltage are sufficiently stable? How's the reference and input voltage generated?
    •   AltAdvertisment
    Nov 2013
    511
    3,417
    13
    Yes, I also think it is not self-oscillation, if the ground connections are good probably with some filtering on the reference/supply you can eliminate this.
    By the datasheet of the LM2902N it has 15dB less supply noise rejection in worst case compared to LM358, maybe this caused a difference.
    •   AltAdvertisment
    Full Member level 2
    Sep 2014
    132
    1,380
    8
    4MHz is the crystal frequency as well. It could be that crappy breadboard or jumper wires. I've already found few not conducting jumper wires..
    Voltages are created by Lab power which can go to millivolt range.
  7. #7
    Points: 38,015, Level: 47
    Mar 2008
    USA
    6,142
    38,015
    47
    If it's truly oscillating then it ought to do the same
    powered from batteries and the input grounded at
    the jack (?), no externalities.
    Any differences you see, ought to point to something.
  8. #8
    Full Member level 2
    Sep 2014
    132
    1,380
    8
    I isolated the microcontroller and put only BC547 transistor which controls 30mA led. Still oscillating. It is the signal from the amplifying U1:A which is noisy. As I had extra OP amp available I used one as a Sallen-Key low pass filter between amplifier and comparator (pin 1-5) and tried to filter the oscillation out. Went as low as 1hZ, 10uF and 15kohm values on that Sallen-Key but still there is few hertz on-off in the hysteresis area. Now it is only 3mv that oscillation area as well. Are those resistor values 1k and 47k in right range for it to work properly? But I have tried 10 higher and lower as well. 100ohm and 4.7k were better though..
  9. #9
    Nov 2013
    511
    3,417
    13
    Did you try to add a capacitor paralel with R3 to filter the input signal?
    Oscillation frequency shouldn't change with adding a filter I think, interesting...
    I would also try to add a filter capacitor with R4 instead of adding a Sallen-Key stage.
    •   AltAdvertisment
  10. #10
    Points: 68,549, Level: 63
    Apr 2014
    13,999
    68,549
    63
    * Do you have a solid GND plane for reliable GND?
    * are there ceramics capacitors at each ICīs supply pin with low impedance connection to GND to stabilize VCC?
    * is it a breadboard circuit?
    * can we see a photo of your circuit or - even better - the PCB layout?
  11. #11
    Full Member level 2
    Sep 2014
    132
    1,380
    8
    Tried cap parallel to R3, no help. I added also cap to the ic supply pin, after taking this picture. Sorry, picture is huge for better visibility.
    0.049V starts oscillating. 0.054V stable. I checked this small input voltage from lab power by oscilloscope and it is stable.
  12. #12
    Apr 2014
    13,999
    68,549
    63
    I assume you did not use all 4 opamps ... and you left some (unused) inputs floating.
    A no-go.
    Besides this I don't think a breadboard is useful for this application.
    I see no GND concept.
    Just connecting some components does not work.
    Better use a simulation tool like Ltspice, it doesn't care about wiring.
