Results 1 to 9 of 9
    Full Member level 6
    Points: 1,363, Level: 8
    Aug 2016
    341
    1,363
    8
    computing rated current for inductors
    I have a CDRH104RNP-331N and there is no current rating column in this sheet.
    https://pdf.datasheet.live/datasheet...4RNP-2R5NC.pdf
    It only depicts saturating current. Can rated current be computed from saturating current?
    •   AltAdvertisment
    Points: 252,660, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,014
    252,660
    100
    Re: computing rated current for inductors
    No. What do you think is the purpose of specified "temperature rise current" other than a current rating?
    Full Member level 6
    Aug 2016
    341
    1,363
    8
    I suppose thats another way to state rated current since above that threshold it will raise temperature damaging the coil.
    •   AltAdvertisment
    Points: 7,139, Level: 20
    Dec 2015
    Madrid, Spain
    1,253
    7,139
    20
    Not above that threshold. At that current rating, it has already risen 30ºC above ambient. Other manufacturers give the rating current for increment of 20ºC. Others, also give you a Temperature vs Current chart, e.g. Wurth.
    •   AltAdvertisment
    Full Member level 5
    Points: 1,648, Level: 9
    Aug 2016
    255
    1,648
    9
    According to the footnote, the temperature rise current is the current value that the inductor would rise in temperature to 50 degC from Ta=20 degC. 50 degC isn't that much of a temperature that the inductor is not supposed to withstand.
    The saturation current would have the inductance drop to 65% of its nominal value. That's to say that a high (in fact destructive high) current will flow. That's what you want to avoid.
    It depends more on where the product with the inductor will be used. If in an area with significant amount of ambient heat like industrial environment or automobile, then I'd say you stay below the temperature rise current value as the temperature will go higher than additional 30 degC. If it's in a domestic environment, then you can go even above the temperature rise current value, but stay well below the saturation current value.
    Okay, I see that the recommended operating temperature ranges up to 100 degC so it is not suitable for automobile application.
    --Akanimo.
    Points: 70,746, Level: 64
    Apr 2014
    14,471
    70,746
    64
    What is going on here.
    I could not open the pdf of post #1 (I always recommend to use the PDFs directly from the manufacturer, they are most up to date)
    The datasheet from manufacturer, dated (Revised: 6-Jan-17) says this:
    3 Temperature rise current: the actual value of D.C. current when the temperature of coil becomes △T=40℃ (Ta=20℃).
  7. #7
    Full Member level 6
    Points: 2,148, Level: 10
    Nov 2016
    348
    2,148
    10
    A sumida datasheet I found shows a 104NP at T=40c. And the 104RNP at T=30c.
    •   AltAdvertisment
  8. #8
    Full Member level 5
    Aug 2016
    255
    1,648
    9
    Obviously, different datasheets revisions with different figures. The datasheet in post #1 must have been revised. It doesn't have a revision date and is from Sumida.
    You should go with the latest revision then.
    --Akanimo.
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,014
    252,660
    100
    First point has been clarified, the Sumida datasheets give sufficient information about current rating.
    Second point is how to read it. Assuming ΔT of 30 or 40 K for Idc temperature rise is just an arbitrary decision. You should be aware that in a usual switcher application, you have both copper and core losses. With high switching frequencies, core losses may cause a temperature rise similar to current related losses, total temperature rise is doubled then. Thus the low seeming 30 or 40 K makes sense.
