Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Full Member level 4
    Points: 1,484, Level: 8
    Sep 2016
    228
    1,484
    8
    Re: Driving Induction motor using TRIAC
    Quote Originally Posted by venkates2218 View Post
    For clarification i'm asking,in the document which you provided about snubber,in many circuits they used the RC across the TRIAC,but here we are taking an tap after RESISTOR.
    What's the difference between RC across TRIAC and taking TAPPING after RESISTOR..?
    If we replacing the TRIAC by relay to control motor means also need snubber..?
    •   AltAdvertisment
  2. #22
    Points: 250,892, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,678
    250,892
    100
    The X2 Capacitors cost 3 to 4 USD. Why not simply use 40A type snubberless TRIAC ?
    47n or 100 nF/275 VAC X2 capacitors from major manufacturers are starting below 50 cent, single quantity at catalog distributors.
    Snubbering the triac is one point and never wrong with inductive loads, although not necessarily required.
    Opto triac dV/dt sensitivity is the other point, and usually more critical. That's why a suggested a modified snubber/filter circuit in post #11. It's discussed in detail in the linked Onsemi application note. With a 220 ohm series resistor, it's absorbing transients across the triac to some extent and to a greater degree filtering the opto triac input voltage. The circuit proved useful for me, but it's surely not the only way.
    •   AltAdvertisment
  3. #23
    Full Member level 4
    Sep 2016
    228
    1,484
    8
    If driving this motor with relay means also have to use snubber..?
