Results 1 to 3 of 3
    Junior Member level 1
    Points: 148, Level: 1
    Sep 2018
    15
    148
    Working of AD8367 evaluation Board
    Hello All,
    Have anyone used AD8367 evaluation board? I have bought it & I am try to understand its working.
    What will be the output level of it when It is in VGA mode, also following are the settings done and input that I have given-
    SW-1 -> A
    SW-2 -> A
    Voltage -> 5V
    V(GAIN) -> 50mV
    INPUT ->
    Frequency= 75 MHz, Level= -40dBm
    Thanks & Regards,
    Pravin.
    Points: 74,693, Level: 66
    Apr 2014
    15,150
    74,693
    66
    Re: Working of AD8367 evaluation Board
    you urgently need to read the datasheet.
    VGA_Mode:
    MODE pin (controlled by SW-2) = VP = 5V
    DETO pin (controlled by SW-1) = V_Gain = 50mV
    Thus - as far as I can see - the gain should be about -3dB
    Sep 2018
    15
    148
    VGA_Mode:
    Thanks,
    Exact result of about -3 dBm I was expecting, but instead of this I am getting -21 dBm. Also in AGC mode, constant level that I am getting is -14 dBm.
