Results 1 to 14 of 14
    Points: 668, Level: 5
    Feb 2017
    40
    668
    How create negative voltage -700mV - -1000mV 30mA?
    I need create negative voltage -700 - -1000mV max current 30mA (typical 5mA) from positive +5 or +3,3V and and all that best in simple and small.
    I thing switching capacitor , but small SMD IC have fixed output for example -3,3 or mirrored to the input voltage and I need -700mV ,
    Any idea?
    Points: 76,326, Level: 67
    Apr 2014
    15,478
    76,326
    67
    Re: How create negative voltage -700mV - -1000mV 30mA?
    What about a SC voltage inverter plus a negative voltage regulator?
    Maybe there are even combined ICs.
    Did you use selection tools provided by the manufacturers?
    Full Member level 6
    Points: 3,545, Level: 13
    Sep 2013
    393
    3,545
    13
    You can use restive divider for voltage splinting + & - voltage for small current application Click image for larger version.
Name:	Split voltage.png
    Feb 2017
    40
    668
    My application not simple and dot low power , I need only small negative for tree CMOS op amp and GND must be GND.
    honestly, I do not even know the integrated negative regulator for one volt or less
    Apr 2014
    15,478
    76,326
    67
    Neither do I.
    Thus one of us or you should use the selection tools provided by the manufacturers.
    I recommend you do this on your own.
    Points: 52,361, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,836
    52,361
    55
    This is a simple negative polarity charge pump circuit. You may find you can use a 555 IC for the role of both clock and half-bridge. Or perhaps it won't work from a 3.3v supply... then you'll probably need to construct an astable multivibrator.
Name:	neg polarity charge pump -800mV 30mA driven from half-bridge clk 4v.png
    The output is negative, referenced to 0v ground.
  7. #7
    Points: 14,677, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,439
    14,677
    29
    Use the classic 7660 IC (has been around for decades) in voltage inverting mode, and clamp the output with a series combination of a small signal diode plus a schottky. A 1N4148 and a 1N5711 should work.
    My batteries are recharged by "Helpful Post" ratings.
  8. #8
    Newbie level 5
    Points: 195, Level: 2
    Oct 2018
    10
    195
    Jadeit
    v_out of ICL7660 depend on capacitors
    so v_out not staple
  9. #9
    Apr 2014
    15,478
    76,326
    67
    This sounds as if one could control the output voltage by modifying the capacitor value.
    Where in the ICL7660 did you read this statement?
  10. #10
    Apr 2013
    2,439
    14,677
    29
    Quote Originally Posted by wondrous View Post
    Jadeit
    so v_out not staple
    That would be the purpose of the output clamping diodes.
    Also where did you read that voltage changes with capacitance on a 7660?
  11. #11
    Points: 258,547, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,138
    258,547
    100
    Regulated SC voltage inverters are available with -1.2V Vref, e.g. lm27761. You may introduce an intentional offset to the feedback path to get lower output voltage.
    Another option, an unregulated SC inverter in combination with one of the very few negative voltage regulators exposing less than -1.2 Vref, e.g. ADP7183.
  12. #12
    Newbie level 5
    Oct 2018
    10
    195
  13. #13
    Apr 2014
    15,478
    76,326
    67
    So output voltage depends on a lot of parameters...
    The whole thing is a voltage inverter with series resistance.
  14. #14
    Newbie level 5
    Oct 2018
    10
    195
    Hi
    @ KlausST : yes sir it's
    @ Jadeit : I wish you all the best and success
