Results 1 to 5 of 5
    Advanced Member level 2
    Points: 6,634, Level: 19
    Oct 2001
    623
    6,634
    19
    Current sampling of dc motor for closed loop control.
    I'm tring to control a brushed dc motor which is 24V, 200W in a closed loop manner. I've confused in the inner current loop section. The current is not steady as shown in the attachment. What should I do here? Get the average or peak value or something else? Thanks.
    Points: 256,119, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,671
    256,119
    100
    Re: Current sampling of dc motor for closed loop control.
    Average current is probably what you want to control, but slows down the loop which has to consider the average filter delay. Peak current control gives fastest response and direct overcurrent protection, but needs slope compensation to achieve stability and also a correction for Ipk/Iavg ratio.
    A higher pwm frequency reduces the Irms related winding losses.
    Advanced Member level 1
    Points: 2,387, Level: 11
    Aug 2016
    414
    2,387
    11
    You can use either. Average current mode control will control it at the average value whereas peak current mode control will control it at the peak value.
    --Akanimo.
    Newbie level 6
    Points: 226, Level: 2
    Jun 2018
    INDIA
    14
    226
    Average current calculation will be better in speed control of DC machines, but then again it is totally dependent over the requirements of the project.
    Points: 74,710, Level: 66
    Apr 2014
    15,157
    74,710
    66
    I_peak is already explained
    I_avg tells you about the motor torque
    I_RMS is good if you want to calculate winding loss. (heating)
