Results 1 to 2 of 2
    Full Member level 1
    Points: 2,035, Level: 10
    Feb 2010
    96
    2,035
    10
    NI-MH Battery charger circuit help
    Friends
    I need a charger circuit for 12x 1.2volt,2100Mah NI-MH Batteries .(14.4V)
    here what will the out put voltage and current for charging this 12 batteries ?
    which switching transformer for suitable this application ?
    Can you help?
    maxim10373
    •   AltAdvertisment
    Points: 8,836, Level: 22
    d123's Avatar
    Jun 2015
    1,577
    8,836
    22
    Re: NI-MH Battery charger circuit help
    These are interesting, not sure if you've seen them. Both say NI-MH are prefereably charged at a C/10 rate.
    BU-408: Charging Nickel-metal-hydride
    NiMH Battery Charging Basics
    I think besides peer reviews of suitable ICs/switching supplies, it's good to go through manufacturers - such as TI, Analog, etc. - NIMH battery charger product parametric search lists and compare a few to see if any are ideal, if an IC is part of what you're looking for.
    I don't know much about this, but I'd guess you'd need something that can put out about half that capacity, so a 1 Amp supply would be ample, if at most it will only ever provide C/3.3 = 2.1/3.3 = ~0.64A (+ any housekeeping current used). And for C/10 = 0.21A minimum charging current required (+ any housekeeping current used).
    One of the links says at 20ºC, minimum charging voltage is 1.41V per cell = 16.92V for 12 cells in series.
    These seem quite complicated to charge and worth understanding the process and pitfalls well before starting.
