Results 1 to 4 of 4
    Full Member level 1
    Points: 987, Level: 7
    ashrafsazid's Avatar
    Sep 2016
    Germany
    102
    987
    7
    Sidelobes from Periodic AC (pac) Analysis
    Is it possible to get an ac transfer curve of a sampled system with all desired sidelobes? I did a pac analysis of SC filter with 20 sidebands and found the behavior like this. But I am interested on getting the side-lobes as like as seen in the textbooks.
    Please help.
    Your life is all about ΔΣ, the narrow you estimate it, the precise it is ...
    Points: 15,517, Level: 30
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,383
    15,517
    30
    Re: Sidelobes from Periodic AC (pac) Analysis
    Quote Originally Posted by ashrafsazid View Post
    What do you want to mean by "sidelobes" ?
    Full Member level 1
    Sep 2016
    Germany
    102
    987
    7
    Quote Originally Posted by pancho_hideboo View Post
    I meant Sidebands.
    Oct 2006
    Real Homeless
    2,383
    15,517
    30
    First of all, what simulator do you use ?
    I meant Sidebands.
    Even if you mean sidebands, I can not understand what you want to plot at all.
    Can you understand PAC(Periodic AC) Analysis ?
    I assume you use PSS/PAC Analysis of Cadence Spectre.
    f(out)= f(in) + Ki * fund(pss)
    f(in) represent the (possibly swept) input frequency.
    fund(pss) represents the fundamental frequency used in the corresponding PSS analysis.
    Default of `freqaxis' is the absolute value of the output frequency(`absout').
    What plot do you want to expect ?
    Show me netlist fragments regarding PSS and PAC.
