Results 1 to 11 of 11
    Full Member level 5
    Points: 1,872, Level: 10
    Sep 2016
    299
    1,872
    10
    Voltage control using PWM
    I having an test panel in that their is an stepup transformer which produce 270VAC from 230VAC.
    I have to use variable voltage from 170VAC TO 270VAC for my operation in specified time.So I tried to bulit an automatic voltage converter to change the voltage from 170VAC TO 270VAC,based on time of operation.
    So I tried it by using PWM output from the PIC controller with BT136,IRF540 and MOC3021 but I can't get any output from it...
    How to control the voltage by using the PWM from PIC controller..?
    Points: 74,732, Level: 66
    Apr 2014
    15,164
    74,732
    66
    Re: Voltage control using PWM
    AC voltage control by PWM? Are you sure? Show your circuit.
    Newbie level 6
    Points: 226, Level: 2
    Jun 2018
    INDIA
    14
    226
    I think the solution to your this problem is a little different. If u want to vary your voltage in AC supply, first detect the zero crossing (any) of the voltage waveform and then vary the duration before giving the gating pulse (at each half of the AC supply to vary the RMS value of voltage) to your BT136 (TRIAC) which will control the output terminal voltage across your load.
    Full Member level 5
    Sep 2016
    299
    1,872
    10
    freq_timer = TMR1L;
                    freq_timer += (TMR1H << 8);
                    freq = (int) (60000.0 / (0.008 * freq_timer));
    Output side of this circuit is connected to fluke meter and checked the frequency,it showing 100.01.
    Then I connected with CCP1 pin of PIC controller and by using the above calculation,it showing nearly 20000 like.
    How to detect the zero crossing..?
    Apr 2014
    15,164
    74,732
    66
    I'm not familiar with PIC,
    But "CCP1" sounds like a capture input.
    When using capture feature you need to setup the capture periferal. I don't see this in your code.
    Please explain how you set up the capture periferal.
    All I see are some values I don't know where they come from.
    Please explain your code and the math behind it.
    Newbie level 6
    Jun 2018
    INDIA
    14
    226
    Quote Originally Posted by venkates2218 View Post
    To Detect the zero crossing of the AC supply, follow the following steps:
    1. AC supply needs to be rectified via bridge rectifier. {Take a parallel connection}
    2. The pulsating DC which you gonna get after step 1 is also having a zero crossing at same position which we need to detect, is given input to the opto-coupler [eg. MOC3043 IC] to protect your micro-controller from over-voltage and over-current from the direct supply.
    3.The DC signal which u get in step 2 is given to the voltage comparator to detect the zero crossing.
    4. Output from step 3 i.e. O/P of voltage comparator is fed to the micro-controller to know the zero-crossing.
  7. #7
    Points: 79,232, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,978
    79,232
    68
    Klaus, CCP1 is one of the capture or PWM output pins depending on configuration. In PWM mode it is an output, in CCP mode it effectively becomes a gate input for counting a clock or a counter input itself.
    I'm not sure why PWM is suggested at all here and I'm not sure triac control is suitable for producing a variable AC voltage unless chopping parts of the cycles is permissible. If PWM is used, it can only be to either control the phase angle the triac is fired, in which case the waveform will no longer be sinus or it can be used to recreate the entire AC waveform in which case zero crossing isn't necessary.
    venkates2218, can you explain which method you are trying to use. From your triac diagram is seems you want to control overall power to a load rather than voltage.
  8. #8
    Points: 14,504, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,414
    14,504
    29
    Are you really attempting to control 270 volts alternating current with a phototransistor?
    My batteries are recharged by "Helpful Post" ratings.
  9. #9
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,978
    79,232
    68
    ... I think that was just to detect zero crossing.
    However, using PIC PWM module usually implies a relatively fast PWM rate so unless this is a full inverter (creating a new AC voltage via a DC source), the PWM signal is useless as a triac trigger.
  10. #10
    Points: 569, Level: 5
    ArakelTheDragon's Avatar
    Jul 2017
    If you like the post, please press "Like".
    48
    569
    I don't know if the forum rules allow this question and us to comment. If they do, it would be best to use a step up transformer for this purpose.
  11. #11
    Points: 51,732, Level: 55
    Apr 2011
    Minneapolis, Minnesota, USA
    12,698
    51,732
    55
    Does your project draw low power? Here is an AC-in-AC-out voltage multiplier. It has positive and negative Villard cells. The transistors feed a true AC sine wave to the load. It allows some room for adjustment (although more effort is needed to create automatic regulation).
    Supply is 170V AC. The load gets 270 VAC
    By selecting small enough values for C1 C2, it produces large voltage swings. Thus the transistors do not need to dissipate so much heat. Bias resistors should be adjusted so the load gets a sinewave at the desired voltage.
Name:	AC in AC out V mult 170v to 270v 100mA 50Hz.png
    Power factor error is high. It can be reduced by installing resistor/ capacitor/ inductor networks inline with the diodes.
