Service Notification
EDAboard.com Scheduled Maintenance for 6/4/2020
Starting at 12:00pm EST Thursday June 4th EDABoard will be in maintenance mode and be unavailable. The website is being migrated to a new web server and the software is being upgraded. With the large volume of data & images to move, migration is expected to last for 8 - 10 hours. When started the forum will go into maintenance mode and no posts, edits or registrations can be made.
Results 1 to 5 of 5
    Junior Member level 1
    Points: 376, Level: 4
    Jul 2017
    18
    376
    PIC16F1508 and MCP9801 simulation in Proteus
    1) I am trying to read the ambient temperature register in MCP9801 with the following code. My simulation is getting stuck on one line (highlighted in code below). I have attached the Simulation log.JPG.
    2) I have referred to the the relevant discussions previously done, but still
    wasn't able to figure the problem in my code.
    https://www.microchip.com/forums/m956027.aspx
    https://www.microchip.com/forums/m852246.aspx
    3) It's been two weeks I have started with MPLAB and PIC controllers. I have written Blinky LED for PIC16F1508, 688 and 1887. Also I have done UART communication using PIC16F1887.
    #include
    #include
    #include
    #include"pic16f1508.h"
    #define _XTAL_FREQ 16000000
    void initialise()
    INTCONbits.GIE = 0; // GLOBAL INTERRUPTS DISABLED
    INTCONbits.PEIE = 0; // PERIPHERAL INTERRUPTS DISABLED
    PIE3 = 0; // INTERRUPTs DISABLED
    SSP1STATbits.SMP = 1; // Slew rate control disabled for Standard Speed mode (100 kHz and 1 MHz)
    SSP1STATbits.CKE = 0; // Disable SMBus specific inputs
    SSP1ADD = 0x03; // CLOCK OF 31.25 KHZ SET
    SSP1MSK = 0; // NO MASK
    TRISBbits.TRISB4 = 1; //
    TRISBbits.TRISB6 = 1;
    ANSELB = 0;
    PIE1bits.SSP1IE = 0;
    SSP1CON1bits.WCOL = 0; // 1 - I2C CAN'T BE STARTED, 0 - GOOD TO GO
    SSP1CON1bits.SSPOV = 0;// 1 - BYTE RECEIVED WHEN SSP1BUF STILL HOLDING LAST BYTE
                                           // 0 - GOOD TO GO
    SSP1CON1bits.SSPEN = 1; // ENABLE I2C
    SSP1CON1bits.CKP = 0;
    SSP1CON1bits.SSPM0 = 0;
    SSP1CON1bits.SSPM1 = 0;
    SSP1CON1bits.SSPM2 = 0;
    SSP1CON1bits.SSPM3 = 1; // SSPM - 1000, MASTER MODE SELECTED
    SSP1CON2 = 0x00;
    SSP1BUF = 0;
    TRISC = 1;
    void first_write()
    SSP1CON2bits.SEN = 1; // START I2C
    while(SSP1CON2bits.SEN | SSP1STATbits.R_nW); // WAIT -(I GET STUCK OVER HERE!!!)
    SSP1BUF = 0x90; // 1001 - DEFAULT ADDRESS(MCP9801), 000 - I HAVE SET THE
                               // LAST THREE BITS OF ADDRESS (MCP9801), 0 - WRITE
    while(SSP1CON2bits.ACKSTAT); // SEE IF ACKNOWLEDGEMENT HAS BEEN RECEIVED//
    SSP1BUF = 0; // TO SET THE REGISTER POINTER TO 00 FOR TEMPERATURE
    SSP1CON2bits.PEN = 1; // STOP I2C
    void one_read()
    SSP1BUF = 0x91; // 1001 - DEFAULT ADDRESS, 000 - I HAVE SET THE LAST THREE
                               //  BITS OF ADDRESS (MCP9801), 1 - READ
    while(0 == SSP1STATbits.BF); // WAIT WHILE RECEPTION NOT COMPLETE
    SSP1CON2bits.ACKDT = 0; // SEND ACKNOWLEDGEMENT
    PORTC = SSP1BUF; //
    void main(void)
                 initialise();
                 first_write();
                 one_read();
ID:	150680Click image for larger version.
    Advanced Member level 3
    Points: 3,642, Level: 14
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    Re: PIC16F1508 and MCP9801 simulation in Proteus
    In Proteus the I2C Pull-up resistors for 100 KHz I2C Clock should be 4.7k and DIGITAL type.
    Jul 2017
    18
    376
    Thanks for that! Does the code look okay ?
    Jul 2017
    18
    376
    Also I have set 31.25 kHz clock frequency in SSP1BUF register(0x03).
    baileychic's Avatar
    Aug 2017
    728
    3,642
    14
    If code is correct then after making the pullup resistors 4.7k DIGITAL type then you should get the readings.
