Results 1 to 4 of 4
    Advanced Member level 3
    Points: 4,925, Level: 16
    PA3040's Avatar
    Aug 2011
    865
    4,925
    16
    Robot for competition
    Hi Team,
    I am planing to build a robot for robot competition
    Following are the parts i am going to use
    AMTGA 328p Microcontroller at 20MHz
    N20 12v 600RPM Chines Motor
    TB6612FNG Motor Driver
    5 Sensor array ( QTRC )
    18650 3.7v x 2 Battery Total Voltage is 7.4v
    I am planing to use Step up voltage regulator to supply 12v for motors
    For the testing I used LM2577 ADJ regulator for my prototype but when battery voltage drooped the output of the Regulator also drooped even battery voltage 7v
    It would be much appreciated if nay one can advise a good step up regulator for my design
    Thanks in advanced
    PA3040
    Points: 12,464, Level: 26
    Apr 2010
    1,895
    12,464
    26
    Re: Robot for competition
    What is the current rating of the 12v DC motor and how many numbers are used?
    PA3040's Avatar
    Aug 2011
    865
    4,925
    16
    Thanks for the reply
    voltage 12 V
    no-load performance 640 RPM, 60 mA
    stall extrapolation 0.39 kg⋅cm (5.4 oz⋅in), 0.75 A
    Gear Ratio 30:1
    Two Motors are using
    Apr 2010
    1,895
    12,464
    26
    From your spec , the load current is well within 2577 capability.
    post the circuit schematic of the designed 2577 reg with comp values to ascertain the possible problems.
