PA3040
Advanced Member level 3
Hi Team,
I am planing to build a robot for robot competition
Following are the parts i am going to use
AMTGA 328p Microcontroller at 20MHz
N20 12v 600RPM Chines Motor
TB6612FNG Motor Driver
5 Sensor array ( QTRC )
18650 3.7v x 2 Battery Total Voltage is 7.4v
I am planing to use Step up voltage regulator to supply 12v for motors
For the testing I used LM2577 ADJ regulator for my prototype but when battery voltage drooped the output of the Regulator also drooped even battery voltage 7v
It would be much appreciated if nay one can advise a good step up regulator for my design
Thanks in advanced
PA3040
Thanks in advanced
PA3040
