Results 1 to 8 of 8
    Full Member level 1
    Points: 1,990, Level: 10
    May 2010
    fdsf
    107
    1,990
    10
    mosfet FDN340P-> DC motor switching
    I want to do PWM from an mcu using a FDN340P mosfet, driving a dc motor, so I made a test, without the mcu first
    if I set the gate to 0 (vss) the motor runs smoothly (200mA)
    if I want to stop the motor, setting the gate to 9v, instead of stopping, it runs slower, but then the current goes up to 3 A and the transistor heats like hell
    this does not make sens at all
    why is the motor not stopping, why is the current raising to 3A while the motor runs slower ? I thought a P-channel mosfet would close itself if set to VCC
    I also tried using a 10k res between 9V and gate but still the same
    regards
    •   AltAdvertisment
    Points: 76,044, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,439
    76,044
    67
    Re: mosfet J201 -> DC motor switching
    Your question is confusing:
    if the device is a J201 as in the title, it is a depletion mode JFET but the pins are correct.
    if the device is a FDN340 you have the pins crossed over and ignore that it is a logic level device. Assuming VSS is negative, you also have the polarity wrong.
    •   AltAdvertisment
    Full Member level 1
    May 2010
    fdsf
    107
    1,990
    10
    I probably was on ***** yesterday, the schematic is not correct, I took the wrong datasheet
    here is the actual schema
    do I have to add a resistor or something ?
    [ ps : I changed the title but it has not changed at the top of the page, only on my post ]
    •   AltAdvertisment
    Points: 250,686, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    43,646
    250,686
    100
    Transistor polarity (PMOS) still doesn't fit the apparently positive power supply.
    It would be helpful to know the motor current consumption with 9V power supply, without any erroneously wired transistors. A possible problem is the maximum gate voltage rating of +/- 8V, connecting 9V between gate and source may have destroyed the transistor.
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    12,439
    76,044
    67
    That's my guess too. I suspect the motor runs slower because of extra load through a shorted gate-source pin inside the FET.
    Rompelstilchen - be careful of the polarity and gate voltage. The device is PMOS so the drain should be negative with respect to the source and the gate voltage should be no higher than 5V above the source voltage. I would advise you add a 1K resistor in series with the gate anyway to prevent high current in case of accidents and add a 100K resistor between gate and source to prevent the gate floating while the switch changes over.
    Full Member level 1
    May 2010
    fdsf
    107
    1,990
    10
    thanks guys I am a complete dummy with analog electronics, first time I use a PNP
    also guessing I fried the poor thing
    I'll make the change and test these
    ok, it works, I'll try now to do pwm from an attiny24
  7. #7
    Points: 49,494, Level: 54
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,613
    49,494
    54
    You had the pins on the Mosfet connected wrong:
    •   AltAdvertisment
  8. #8
    Newbie level 5
    Points: 147, Level: 1
    Jun 2018
    10
    147
    Before giving the response I would like to know motor specification to be sure... Kindly share motor specification also..
