Results 1 to 6 of 6
    Member level 5
    Points: 884, Level: 6
    azadfalah's Avatar
    Aug 2016
    90
    884
    SMPS inrush current limiter to protect the secondary diodes
    Hello friends
    please guide me. What is the charge current of the capacitors in the circuit below?
    And how is inrush current limited?
    Are Rectifier Diodes Damaged?
    •   AltAdvertisment
    Points: 9,142, Level: 22
    d123's Avatar
    Jun 2015
    1,617
    9,142
    22
    Re: SMPS Inrush Limiter to protect the secondary diodes
    Not sure if this will help at all:
    Design Guide for Rectifier Use Hammond 5c007.pdf
    I am not familiar with series chokes in power supplies, I've seen a low value series resistor before the capacitors to limit the inrush current.
    If you get the datasheet for the MUR1560 and check the diode's ratings, then you can compare it with the power drawn by the expected/maximum load and check the peak impulse rating is much higher than you are expecting.
    •   AltAdvertisment
    Points: 70,834, Level: 64
    Apr 2014
    14,486
    70,834
    64
    The picture shows the secondary part of a switch mode power supply.
    The shown circuit does not work without (primary side) SMPS controller.
    Inrush current limiting is done by the SMPS controller.
    •   AltAdvertisment
    Member level 5
    azadfalah's Avatar
    Aug 2016
    90
    884
    Complete schematics
    Points: 77,386, Level: 67
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,667
    77,386
    67
    The NTC thermistor in the AC input limits the inrush current. There is no need to limit the current to the output rectifiers as well.
    •   AltAdvertisment
    Points: 252,756, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,024
    252,756
    100
    More specifically, the SG3525 soft start circuit limits the transistor and rectifier current during start. With 33 uF it's dimensioned extremely slow.
