Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 65
    Member level 4
    Points: 766, Level: 6
    Dr_Mohammad's Avatar
    Nov 2016
    Khorramabad, Iran
    71
    766
    how to design a thermostat without Microcontroller?
    hi every one
    I want to have an electronic thermostat when the tempearture reaches to 37 C turn a relay Off.
    do you have a circuit?
    thanks
    Hope is a good thing, maybe the best of things and no good thing ever dies (The Shawshank Redemption).
    Points: 74,693, Level: 66
    Apr 2014
    15,150
    74,693
    66
    Re: how to design a thermostat without Microcontroller?
    And never turned ON again?
    Why "electronic" but "no microcontroller"?
    Why not mechanic?
    What relay? Voltage, current?
    What supply voltage is available? what current?
    Please dont contact me via PM, because there is no time to respond to them. No friend requests. Thank you.
    Points: 9,710, Level: 23
    d123's Avatar
    Jun 2015
    1,717
    9,710
    23
    How easy or simple? I have this circuit, not fantastic but functional:
Name:	basic thermostat.JPG
    And this is two circuits pasted together to give the general idea:
Name:	on off heater v3 schematic trimmed.JPG
    I'm sure there are other solutions and the above can be improved upon a lot.
    For no microcontroller, and for it to be "easy" to put together, you need at least a reference, a temperature sensor, a comparator, a BJT or MOSFET and a relay, then stuff like passive components and fuses.
    Points: 79,227, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    12,976
    79,227
    68
    Anything that changes resistance with temperature or produces a voltage changing with temperature can be used to drive a comparator. If you want to avoid a hard switching at one particular temperature so the relay doesn't 'chatter', add some feedback so the upper and lower temperature points are slightly apart.
    Member level 4
    Nov 2016
    Khorramabad, Iran
    71
    766
    Why not mechanic?
    hi Klaus
    it should be ON again after temperature goes below 37C.
    I'm not interested in microcontroller because my studies are in Photonics and semiconductors for 6 years. moreover I need a simple circuit and microcontroller increase complexity.
    it should be elctronic because I hate mechanic [lol].
    the relay is used to switch the heater OFF.
    The power supply of the heating source is 220V AC and thermostat should switch it OFF. the power supply of thermostat is 12v but if you have an idea to working it in 220vAC plz give it.
    Hi Brian.
    this thermostat shoulde be placed into a incubator. when the temperature in the box reaches to 37C the thermostat switch the heater OFF.
    Points: 38,970, Level: 48
    Mar 2008
    USA
    6,300
    38,970
    48
    If you know the specific temperature and have no need to
    change it, you probably can't do better than a Selco 'stat
    from Digi-Key or wherever; just a bimetal snap action
    thermal switch, sold in increments of setpoint, cheap.
    However for higher power you'd want to use one to run
    a bigger relay and make sure you protect the contacts.
  7. #7
    Points: 256,096, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,659
    256,096
    100
    Using a simple on-off controller (also called bang-bang controller) for the incubator will result in a relative large periodic temperature variation due to the dead time between sensor and heater. To reduce variation range, you need to follow a different controller concept, e.g. PI controller with pulse width modulator.
  8. #8
    Apr 2014
    15,150
    74,693
    66
    Please review your specification: ON above 37.00000C, OFF below 36.99999C. Are you sure you want this?
    Usually it makes no sense to decide ON/OFF in micro degrees. Noise will cause malfunction.
    This is a too general statement, thus I can't agree.
    From hardware view: what can be less complex than an 8 pin microcontroller with inside clock and temperature sensor?
    You may adjust timing and temperature levels precisely, without additional hardware...
    I see the main job is to switch ON/OFF a heater. But why did you specify a relay? Why no MOSFET, BJT, triac...?
    Btw: a relay is "mechanics"...
    Does this 12V supply already exist?
    It's quite unusual to run such electronics from 220V AC.
    12V DC is not unusual, but 5V DC, or 3.3V DC is more common.
    We don't know your "real" requirements. Like cost, size, quantity, environmental (temperature, humidity, dirt, hygienic..), efficiency, power...
    It may be a wall wart laying around, or an industrial open frame SMPS installed in a sealed metal box...
  9. #9
    d123's Avatar
    Jun 2015
    1,717
    9,710
    23
    You can use the (cheap, small footprint) TL431 or TLV431 as a comparator (Using the TL431 as a Voltage Comparator) and the (cheap, small footprint) LM334 as a temperature sensor, or something simple (and smaller footprint than lm334 temp sensor circuit) like the LM35 Centigrade temperature sensor (cheap, easy to implement and small footprint). Three parts plus passives: reference, comparator and temperature sensor. I don't recommend using a BJT or a diode as a standalone temperature sensor, the BJT one needs an op amp to amplify the 60mV or so that its VBE changes across a wide temperature range... Microchip TC7106/7 datasheet shows how to use a simple (and cost, 1 cent) 1N4148 as a temperature sensor (with the ADC).
  10. #10
    Member level 4
    Nov 2016
    Khorramabad, Iran
    71
    766
    hi Klaus. thanks for your kindly replies.
    I want to design an INCUBATOR. I provided a box which the heating source (40W light bulb), a little DC motor for rotating eggs and a thermostat embedded in.
    the temperature in the box should be around 37C and the accuracy is not too important. I want when the temperature reaches to 37C the light bulb be turned OFF and once the temperature goes below 37C the light bulb be turned ON.
  11. #11
    Apr 2014
    15,150
    74,693
    66
    Please understand: we all know what you want to use it for, but if you want us to help you with your design we (additionally) need technical/electrical specifications.
  12. #12
    Points: 29,139, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,675
    29,139
    41
    Blog Entries
    9
    Quote Originally Posted by Dr_Mohammad View Post
    You migh be aware that thermostats are commonly based on hysteresis working principle, on which the shutdown temperature is a bit higher than the turn on temperature, when used as heat control. Although the propagation of temperature from the heat source toward the sensor, by itself, somehow provides this feature, as stated above, this gap is useful both to preserve the life span of the whole system and also to turn it more immune to unwanted triggering due to measurement noise.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  13. #13
    Advanced Member level 3
    Points: 5,173, Level: 17
    Feb 2014
    714
    5,173
    17
    You asked for a circuit here is a circuit:
    Use a temperature sensor IC like LM50 and send its output to a comparator. The LM50 puts out about 0.87V at 37C.
    http://www.ti.com/lit/ds/symlink/lm50.pdf
    Page 11 shows a complete thermostat circuit with a voltage reference and comparator. R1 and R2 should set a divider to 0.87V. R3 should be about 100X as large as R2 to set the hysteresis.
    Almost any comparator or voltage reference could be substituted. The circuit might benefit from a relay driver in the form of a mosfet (See NUD3112)
    Also you can just buy these controller for cheap:
    https://www.amazon.com/Temperature-C...18471013&psc=1
  14. #14
    Member level 4
    Nov 2016
    Khorramabad, Iran
    71
    766
    Design of an incubator temperature controller
    Hi everyone. The previous post have requested to be deleted because was not complete.
    I have a box which is used to be an incubator. A heating source(40W light bulb) and a Thermostat which controls the temperature. The needed temperature for eggs should be between 36 and 37c. It means if temperature reaches up to 37,the thermostat turns the heater off and if goes below 37 the thermostat turns a light ON again. The power source for light bulb is 220v AC. I dont want to use a microcontroller. Thanks for your kindly replies.
    Last edited by FvM; 7th January 2019 at 09:42. Reason: Threads merged. According to forum rules, we never delete threads that have answers unless they violate the rules
  15. #15
    Nov 2006
    Brazil
    8,675
    29,139
    41
    Blog Entries
    9
    You did not realize yet that there is a difference between the desired working and the accomplishable working. If you want that a temperature remains as close as possible of the target value 37 degree, you need to consider a better approach, as for example the PI control above mentioned at post #7, on which heating addition are made softly. Another point you should consider is that in a heating project, the proper sizing of the heat source and the load (thermal capacity) should be compatible with the allowable thermal range, ie you not only take care to inject heat but also to have adequate thermal isolation, so that with the addition of small packets of heat is enough to keep the air temperature stable.
  16. #16
    Mar 2008
    USA
    6,300
    38,970
    48
    Here's one other "out of the box" (or rather, retail-in-box)
    solution: get a cheapo forced air heater. They have the
    thermostat(duh) and I picked up a couple the other day
    for $12 each (cheaper, it turns out, than many snap-action
    thermostats or semiconductor thermostats). You'd have to
    find the range and then make it permanent-ish (like pull the
    knob off). Fan forced will cut the hysteresis to a minimum
    (snap-action only, not embedding the thermal transport
    as an adder to the toggle-swing).
    Now if the designing of it is the goal, and not just getting
    on with the poultry business, then maybe this is irrelevant.
    But might be worth a look just on the basis of "cheap and
    effective".
  17. #17
    Member level 4
    Nov 2016
    Khorramabad, Iran
    71
    766
    Quote Originally Posted by andre_teprom View Post
    dear Andre, please read my post then spread your thoughts! I think you did'nt realize yet what I need! It's simple. believe! the incubator is a box which a 220V AC light bulb is embedded in as a heater and a thermostat controls it.no additional device or accuracy is needed! the temperature should be in 36-37 degree.
  18. #18
    d123's Avatar
    Jun 2015
    1,717
    9,710
    23
    After multiple circuit suggestions, have you done any research and/or simulation/prototyping of your own yet?
    I don't think 36C on, 37C off is a sensible design approach, it is a very narrow window - the relay will be going on and off every second and the light bulb will be flickering like a strobe light. Presumably it can be extended to e.g. 32C on, 40C off or similar wider range.
  19. #19
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,659
    256,096
    100
    Even with very small hysteresis, the control system will unlikely act very fast. Reason is the "plant" transfer function, which can be modelled as combination of dead time and multiple low passes. If the temperature sensor e.g. detects exceedance of the 37 C set point value and the heater is switched off, the hot light bulb will further heat up the incubator. The actual value over shoots respectively and similarly under shoots after heater switch on.
    It might be that with careful selection of heater power and well considered sensor placement, the temperature variation can be held in an acceptable range. Unless you are able to predict the control system behavior in an exact simulation (very unlikely, I guess), you need to check it empirically.
  20. #20
    Member level 4
    Nov 2016
    Khorramabad, Iran
    71
    766
    Quote Originally Posted by d123 View Post
    I do'nt have any circuit to be simulated
    accuracy is not important. thermostat should turn a relay ON and the relay turn the light OFF. LM35 or a NTC is a good choice but a functional circuit has not founded yet.
