Results 1 to 8 of 8
    Junior Member level 2
    Points: 425, Level: 4
    Jul 2017
    20
    425
    ISE Project navigator while implementation is turned off
    Hello, during implementation in ISE PN (specifically during fit) the program is unexpectedly turns off, without any error or warning. Does anyone know why?
    Points: 8,276, Level: 21
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,232
    8,276
    21
    Blog Entries
    Re: ISE Project navigator while implementation is turned off
    No.
    You can report it to Xilinx if you want through their global forums website.
    FPGA enthusiast!
    Full Member level 1
    Points: 895, Level: 6
    Dec 2017
    Bydgoszcz - Poland
    116
    895
    Quote Originally Posted by frdm90 View Post
    what OS are you using (also version 32 or 64 bit). Which version of Java you has installed (also number and 32 or 64 bit)? How much RAM you has installed and what CPU?
    Jul 2017
    20
    425
    16GB RAM, i5-8400 2.8GHz, Windows 10 64b Java 8
    Points: 30,683, Level: 42
    ads-ee's Avatar
    Sep 2013
    USA
    7,055
    30,683
    42
    I'm not sure if ISE was ever ported to work on Windows 10. 14.7 is the last version of ISE and it was released before Windows 7 came out.
    I would check the ISE 14.7 release notes/docs to see if they have a version that supports Windows 10. They may have created one as they still sell some of the older parts and you can't buy a PC with a older version of Windows.
    You could always install ISE on a Linux partition and dual boot or use a Linux/Win7 VM.
    Full Member level 1
    Dec 2017
    Bydgoszcz - Poland
    116
    895
    Quote Originally Posted by ads-ee View Post
    I don't know if it is supported on Windows 10, but I am using it on this OS. There are problems with 64-bit version - similiar to that described by coleague making this post.
    I am using 32-bit version and it works OK on Windows 10 (64-bit), but is working noticeable slower than 64-bit version of ISE.
  7. #7
    Full Member level 1
    Points: 1,588, Level: 9
    Nov 2013
    117
    1,588
    9
  8. #8
    dpaul's Avatar
    Jan 2008
    Germany
    1,232
    8,276
    21
    Blog Entries
    @OP,
    I think your OS is the issue.
    Read this AnswerRecord from Xilinx: https://www.xilinx.com/support/answers/18419.html
    None of the ISEs support Win10.
    You should use a recommended version to avoid surprises.
    FPGA enthusiast!
