Results 1 to 2 of 2
    Junior Member level 1
    Points: 758, Level: 6
    Jul 2015
    18
    758
    Coupling capacitance between clock signal and voltage signal.
    One voltage signal running in parallel with clock signal.Here,how the switching clock signal affects the voltage signal in capacitive coupling mode...??
    •   AltAdvertisment
    Points: 38,410, Level: 47
    Mar 2008
    USA
    6,215
    38,410
    47
    Re: Coupling capacitance between clock signal and voltage signal.
    Quote Originally Posted by saha.123 View Post
    What's the mystery here?
    You have an "aggressor" (clock) with an intrinsic impedance
    (R, L, Ccouple) and you have a "victim" (shunt C, mostly).
    You could set up a simple SPICE simulation and observe the
    effect as a function of coupling capacitance (parallel length
    and separation) and driving impedance (MOSFET and trace).
    At low coupling C you will see edge "glitches" and at higher C
    you may see the square wave at increasingly high amplitudes.
    Victim shunt C (and R if any) will dilute the injected noise.
    Clock coupling can also make deterministic jitter on near-aligned
    data signals and product clocks (have seen co-routed 60MHz
    and 90MHz clocks "chest-bump" each other every other cycle)
    when coincident, anti-coincident edges speed up or slow down
    a transition (in this case, who is the victim and who is the
    aggressor, or both just come out bloody?).
