Results 1 to 5 of 5
    Points: 32,037, Level: 43
    Sep 2008
    cambridge
    6,684
    32,037
    43
    What do you call a ceramic SMD cap in a metal frame?
    We have a 100n, 1812, X7R ceramic capacitor which sometimes cracks when the PCB that it sits on is screwed to the heatsink (there is flexion during the screwing as some of the PCBs are slightly bowed). There is no room to move, or even to rotate the capacitor.
    We therefore need a “board flexion capable” version of this capacitor…….these are easy to find on digikey etc. (EG "Flexiterm" etc)
    But as you know, there is another option to mitigate board bending….involving a “lead frame” for the SMD capacitor……you can buy the capacitor installed into such a lead frame….but what is the search term that we must use in digikey in order to find such a “capacitor in a frame”?
    Points: 79,430, Level: 68
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,011
    79,430
    68
    Re: What do you call a ceramic SMD cap in a metal frame?
    That sounds so much like a Christmas cracker joke
    I suppose the answer should be 'prisoner'.
    Seriously, given the additional cost, have you considered fitting it, or at least soldering one end AFTER the board has been secured. Not a technical solution but probably the most pragmatic one, especially if you have any other hand assembly operations.
    Brian
    Points: 256,679, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,780
    256,679
    100
    MLCC with J-leads
    Sep 2008
    cambridge
    6,684
    32,037
    43
    Thanks, is MLCC with J leads less susceptible to cracking under board flexion.?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,780
    256,679
    100
    That's the idea. Better withstanding mechanical and thermal stress.
