Results 1 to 11 of 11
    Points: 347, Level: 3
    Sep 2018
    48
    347
    Tuning of transconductance in OTA circuit
    Hi
    I want to tune the transconductance of OTA. For transconductance tuning I have to vary the biasing current but How can I vary the biasing current what circuitry should be used to vary the biasing current for transconductance tuning.
    Points: 40,354, Level: 49
    LvW's Avatar
    May 2008
    Germany
    5,781
    40,354
    49
    Re: Tuning of transconductance in OTA circuit
    Do you speak about a commercial OTA unit?
    In this case, the data sheet gives you some information about the corresponding pin and the internal voltage at this pin.
    Sep 2018
    48
    347
    Quote Originally Posted by LvW View Post
    No, I am taking about the schematic diagram to simulate in CADENCE. How can I tune the biasing current? There might be some tuning circuitry that can be varied which can tune the transconductance.
    Points: 256,061, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    How about a variable current source?
    Sep 2018
    48
    347
    Yes, but after simulating I have to fabricate chip I think while to fabricate the circuit we might have to use some tunable circuitry to vary the biasing currents? The current source can not be fabricated like this? This is what I understood Correct me if I am wrong?
    LvW's Avatar
    May 2008
    Germany
    5,781
    40,354
    49
    How about a simple (large) resistor?
    Do you need linear tuning?
  7. #7
    Sep 2018
    48
    347
    Yes I need linear tuning.
    How simple resistor vary the bias current. If resistor value fixed then tuning is not possible. Normally OTA are electronically tunable. There biasing currents can be tuned. I also want to tune the biasing current.
    OTA is electronically tunable. I want to tune the OTA biasing current how can I tune that. The tuning circuitry in different research articles are not shown. What circuit can be designed/used to tune the biasing of OTA.
  8. #8
    Points: 74,672, Level: 66
    Apr 2014
    15,143
    74,672
    66
    Did you read and try post#4?
  9. #9
    Sep 2018
    48
    347
    How can I design a variable current source. I have provided biasing of the OTA simply by using current mirrors so I have a fixed current. For tuning how can I design a variable current source. I have to fabricate the OTA.
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    44,650
    256,061
    100
    Typical OTA ICs have current mirror inputs for bias setting
    You didn't yet mention what's the characteristic of the involved tuning source. If it's a voltage source and you want a linear tuning characteristic, you'll design a linear V/I converter. I presume it's discussed somewhere in your analog design text books.
  11. #11
    Newbie level 1
    Points: 459, Level: 4
    Dec 2016
    459
    Hi mate, You can use current mirror based binary DAC topology.
