ESC components and battery
kingkongjong
Junior Member level 1
Hello
I am about to buy a motor and esc kit and I had a few questions. I looked online for the escs and I noticed they don't label the escs. So I was wondering is there any way to figure out what the wires on the receiver are. I was wondering how do you know which wire is the signal wire and which is the ground and vin. The esc I am looking to buy has receiver that is made up of yellow, red, and brown wire. Not sure
what each wire does. Also how can you tell what lipo battery is needed for the esc. I would appreciate any help.
The datasheet for the ESC should list its detailed spec's about maximum voltage and current for it to drive a recommended motor from a recommended Li-PO that also should be listed. Of course the functions of the wires should also be shown. If the motor is brushless then it is driven with 3 wires.
The three blue wires go to the motor (if the motor runs in reverse, you need to reverse any two). The red-black pair goes to the power supply. The connector goes to the board.
