Results 1 to 2 of 2
    Member level 4
    Points: 859, Level: 6
    Feb 2017
    74
    859
    Polarizer axial ratio
    Hi. I'm trying to design a Ka band Tapered corrugated polarizer. I somewhat was able to keep phase difference stable but the S parameters differ alot. What i was trying to ask when I search the papers they only use the phase difference between the ports for axial ratio calculation but not the amplitude difference. Shouldn't the amplitude difference be near 0 aswell for a true circular polarization. Like this it is an RHEP LHEP not RHCP and LHCP?
ID:	150363Click image for larger version.
Name:	phase difference.png
    Member level 4
    Feb 2017
    74
    859
    Re: Polarizer axial ratio
    I solved it. I was comparing first mode and second mode for phase angle which ofcourse gives 90 degree difference all times.If you are holding the polarizer 45 degree angled.
