Results 1 to 4 of 4
    Newbie level 6
    Points: 1,113, Level: 7
    Mar 2013
    13
    1,113
    7
    How to improve bandwidth (BW) of serial feed microstrip array antenna?
    1. I need to design and simulate serial feed microstrip array antenna at frequency of 120 GHz.
    2. How can I improve the bandwidth (BW) of the serial feed microstrip array to 10% at least?
    3. Can you attach an example?
    •   AltAdvertisment
    Points: 33,513, Level: 44
    Oct 2001
    4,795
    33,513
    44
    Re: How to improve bandwidth (BW) of serial feed microstrip array antenna?
    My question is: before this 120GHz project, did you try to improve the bandwidth of other microstrip antenna array, let's say working on 2.4GHz?
    Going on 120GHz without very very deep knowledge of microwave circuits, is like stepping on the driver seat of a Bugatti Chiron without a driver license.
    •   AltAdvertisment
    Newbie level 6
    Mar 2013
    13
    1,113
    7
    I already improved the bandwidth of a simple microstrip patch antenna at 120GHz by parasitic element to 14%.
    The bandwidth of serial elements microstrip array antenna is about of (1-3)% and I need at least 6% at a frequency of 120 GHz.
    Can someone help me?
    •   AltAdvertisment
    Full Member level 1
    Points: 776, Level: 6
    Oct 2017
    103
    776
    Assuming you want to stick with single layer, so no aperture coupling/etc.
    1) do not use patch antenna, use other antenna elements, for example ME-dipole (using vias).
    2) if you want to use patches, first try patch arrangement described in patent US20130321214 (pdf link).
    3) use differential-fed patches in your array
