Results 1 to 3 of 3
    Member level 5
    Points: 558, Level: 5
    Nov 2017
    80
    558
    Voltage drop across cascode amplifier
    I can say that I understand simple current mirrors fairly well, but what i do not understant is the minimum output voltage requierd for the circuit to work properly...for the transistors to be in saturation.
    NMOS cascode current mirror
    Vout=V(D4). Vds_sat is the saturation voltage of the transistor M2 and M4. Vt is the treshold voltage.
    Why is the minimum output voltage, on the drain of the M4, equal to the Vout_min=Vt+2*Vds_sat, why not only 2*Vds_sat?
    What will be the voltage drop for self cascode current mirror. How is it equal to 2vdsat.
    •   AltAdvertisment
    Advanced Member level 3
    Points: 5,300, Level: 17
    Dominik Przyborowski's Avatar
    Jun 2013
    Norway
    704
    5,300
    17
    Re: Voltage drop across cascode amplifier
    Cascode transistor and it biasing can be considered as so-called "gate follower".
    In the first figure, source terminal of Q4 copying the source potential of Q3, which is nothing more like Vgs of Q1=Vdsat1+Vth1. So, this cascode current source working properly as long as Vout-VS(Q4) > Vdsat4. However VS(Q4) is already equal to Vdsat1+Vth1. When we decrease the Vout below Vth+2Vdsat, cascode transistor Q4 is in linear region (as long Vout>Vgs(Q1) potential at source of Q4 is constant) and the circuit acts as simple current mirror.
    •   AltAdvertisment
    Points: 309, Level: 3
    Sep 2018
    48
    309
    Thanx for your reply. What about the second circuit. The drain of upper transistor is connected to gate of the lower transistor. So will vout = vgs1 (lower transistor). Both transistor will be cutoff if i consider this case
