Results 1 to 6 of 6
    Advanced Member level 1
    Points: 3,148, Level: 13
    rahdirs's Avatar
    May 2013
    Mordor
    421
    3,148
    13
    Verilog Interview Question
    I was recently asked this question in a Logic Design/DV interview,
    Suppose you have the following, what should be the bit width of c,d,e ? The interviewer said that the answers of my d & e were wrong. For e my answer was based on 3 as 2'b11 which would give a width of 18. What do you guys think ?
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    // The code is my interpretation of his question.
    logic [9:0] a; // can be anything, 9 & 8 were chosen as random
    logic [8:0] b;
    logic [?:0] c; // 17 wide ?
    logic [?:0] d; // 18 wide ?
    logic [?:0] e; // ??
    always @(posedge clk) begin
    // Assume you can finish in 1 cycle
     c <= a*b; // I think c should be at least 8+9 bits wide ?
     d <= a*b + 1'b1; // d should be atleast 17 (^) + 1 bits wide ?
     e <= a*b + 3; // what does the 3 here mean ?
    //In my 2-3 years of RTL experience I only saw people using the syntax 2'b11 or something like that.
    //The interviewer was interested in what would verilog interpret the 3 as ? Is it hex by default ? 4'h3 ??
    end
    If I helped you, press the 'Helped Me' button.
    It's only my opinion, and sometimes I'm wrong.
    Points: 32,539, Level: 44
    ads-ee's Avatar
    Sep 2013
    USA
    7,527
    32,539
    44
    Re: Verilog Interview Question
    [9:0] is 10 bits wide, i.e. 9,8,7,6,5,4,3,2,1,0 which is 10 digits.
    [8:0] is 9 bits wide
    a*b is 19 bits wide not 17 (9+8)
    a*b +1'b1 will be 19 bits wide not 20, a*b will never be all 1's so adding a 1'b1 will never increase the result's bit width.
    a*b +3 will fit in 19 bits but the result is 32-bits due to the 3 which is an integer (dependent on implementation, but is normally 32-bit)
    I've been using Verilog for ~20 years, so I've probably seen + used with practically every possible thing.
    The integer math is the most annoying as it causes additional warnings in synthesis when it sees a 32-bit result being assigned to a smaller bit width variable. As long as you're willing to ignore those (I usually do) and can get through any reviews with those warnings in your synthesis report they aren't a problem.
    Points: 9,420, Level: 23
    Apr 2016
    1,958
    9,420
    23
    ads-ee answer is correct. but damn, what a weird question to ask in an interview. knowing or not knowing this doesn't make you a good designer.
    Really, I am not Sam.
    Points: 6,599, Level: 19
    Feb 2015
    1,065
    6,599
    19
    This looks like a fine interview question. especially if the job is for an engineer that will work on porting dsp algorithms to HW. The OP just managed to hit every off-by-one error possible.
    The addition of an integer literal 3 could bring up the 32b (possible) conversion, but I would expect the smaller width answer to be accepted.
    A weird question would be "y <= (x + 3) >> 1;" vs "y <= (x + 2'd3) >> 1;".
    rahdirs's Avatar
    May 2013
    Mordor
    421
    3,148
    13
    Quote Originally Posted by ads-ee View Post
    Sorry about this one, I posted this question in a hurry without checking the width of a & b in code. As it's a phone interview, the question was just multiply a 9 bit register & a 8 bit register - what's the outcome. So i just remembered my answer of 17. My apologies for writing a 9 bit reg as logic [9:0] a.
    Shoot, I just answered that it will overflow to 20 bits. Now I realize that unless you add (19'h111FFFF - max possible a*b) only then we overflow
    By implementation, are you talking about the environment setup
    ads-ee's Avatar
    Sep 2013
    USA
    7,527
    32,539
    44
    Quote Originally Posted by rahdirs View Post
    software implementation of the number of bits used by a long integer. Most software implementations consider it to be 32-bits, I can't think of any simulators/synthesis tools that consider an integer in Verilog to be anything other than 32-bits, e.g. 64-bits or 128-bits. If I remember correctly the LRM states the size of an integer has to be at least 32-bits.
